Is it safe to control a 4-pin fan with a 2-pin header as used in the Corsair 600t built in fan controller? I'm concerned about damaging either the header or fan itself and can't seem to find any information myself. Thanks in advance and sorry if it's a stupid question.
https://linustechtips.com/topic/98825-quick-question-about-fans/
It should be fine, the extra cords are for pwm and controling the fan over the motherboard I think
CPU: i5 3570k CPU Cooler: Hyper 212+ Mobo: Asrock Pro 4 Z77 GPU: Sapphire Tri-X R9 290 PSU: Seasonic G 650w HDD: Seagate Barracuda 1TB SSD: Kingston v300 Sound Card: Asus xonar dg MonitorAcer K272HUL, HP 22bw
Keyboard: Corsair K70 Mouse: Logitech G400 Mousepad: Steelseries Qck+ Case: Corsair Air 540 Fans: 4x Noctua NF-P12 (saving up for more)
https://linustechtips.com/topic/98825-quick-question-about-fans/#findComment-1322784
Yes it is fine. A 4 pin fan is specifically a PWM. IIRC, pin 1 and 2 are power, pin 3 is fan RPM (fan reports this to the motherboard) and the 4th is for PWM. So, as long as pin 1 and 2 are connected, the fan will have power, the rest are just additional things that are additional benefits, but not nessesary.
15" MBP TB
AMD 5800X | Gigabyte Aorus Master | EVGA 2060 KO Ultra | Define 7 || Blade Server: Intel 3570k | GD65 | Corsair C70 | 13TB
https://linustechtips.com/topic/98825-quick-question-about-fans/#findComment-1323547
These two are correct(amundo)
My Best 2013 Bitfenix Prodigy Build  Case: Bitfenix Prodigy White | Motherboard: ASRock Z77E-ITX | CPU: Intel i7 3770k | CPU Cooler: H100i | GPU: GTX 690
Fan Controller: Bitfenix Recon | Ram: Patriot IEM 16GB @ 1600mhz | Primary Storage: 2 x Samsung 840 Pro 256GB | Backup Drives: 2 x Seagate Barracuda 2TB | PSU: Seasonic X850
https://linustechtips.com/topic/98825-quick-question-about-fans/#findComment-1323591
