hello,
I thought this was the best place to put this but idk.
I have a bcd to 7 segment display converter coded and a bcd counter but I'm struggling on how to link them together.
-many thanks
If you judge a fish based on its ability to climb trees it will go its whole life thinking its a failure.
https://linustechtips.com/topic/988239-verilog-help/
nevermind managed to do it :D
here's my code
module counter    (
   out     ,  // Output of the counter
  enable  ,  // enable for counter
  clk     ,  // clock Input
  reset   ,
seg   // reset Input
  //----------Output Ports--------------
      output [3:0] out;
		output [7:1] seg;
 //------------Input Ports--------------
      input enable, clk, reset;
 //------------Internal Variables--------
      reg [3:0] out;
		reg [7:1] seg;
 //-------------Code Starts Here-------
 always @(posedge clk)
 begin
 if (out == 9)
	out <= 8'b0;
else if (reset)
  out <= 8'b0 ;
 else if (enable)
    out <= out + 1;
end
always @*
begin
case (out)
/*makes stuff opt on seg
stuff on lhs is 'filter' for case using bcd
stuff on rhs is what outpts on seg outputs
~ is used to invert the binary on rhs (makes it easier)
4'b0000:seg=7'b0111111;
4'b0001:seg=7'b0000110;
4'b0010:seg=7'b1011011;
4'b0011:seg=7'b1001111;
4'b0100:seg=7'b1100110;
4'b0101:seg=7'b1101101;
4'b0110:seg=7'b1111101;
4'b0111:seg=7'b0000111;
4'b1000:seg=7'b1111111;
4'b1001:seg=7'b1101111;
default : seg= 7'b1111111;
endcase
end
  endmodule
Edited by Matty2048
that other code was wrong
https://linustechtips.com/topic/988239-verilog-help/#findComment-11903665
