Yo! I use forums too much so, hopefully, this will be my last time while on this topic. I updated my Intel/Nvidia build to now be Ryzen/Nvidia and saved about a hundred bucks for pretty much the same performance.
I'm just wondering if this build looks solid to pick up ASAP I want to buy like tomorrow pretty much. Tired of waiting, just want some input! Thx!
NOTE: I'm buying the WD SSD and the EVGA PSU because they're both on sale. Everything else is changeable, even though I don't want to go through everything again.
I don't want to go far above 1600 dollars... I'll be streaming and gaming at 1080p until I can upgrade to 1440p. 144 Hz. Located in the US
PCPartPicker part list: https://pcpartpicker.com/list/qBrY8Y
Price breakdown by merchant: https://pcpartpicker.com/list/qBrY8Y/by_merchant/
CPU: AMD - Ryzen 7 2700X 3.7GHz 8-Core Processor  ($309.79 @ OutletPC)
Motherboard: Asus - Prime X470-Pro ATX AM4 Motherboard  ($158.45 @ OutletPC)
Storage: Western Digital - Blue 250GB 2.5" Solid State Drive  ($53.65 @ Walmart)
Video Card: Gigabyte - GeForce GTX 1080 Ti 11GB Gaming OC 11G  Video Card  ($714.98 @ Newegg)
Case: Fractal Design - Meshify C White TG ATX Mid Tower Case  ($85.90 @ Newegg)
Power Supply: SeaSonic - FOCUS Plus Gold 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($89.99 @ Amazon)
Other: CORSAIR Vengeance RGB Pro 16GB (2 x 8GB) 288-Pin DDR4 SDRAM DDR4 3000 (PC4 24000) Desktop Memory Model CMW16GX4M2C3000C15W  ($155.99 @ Newegg)
Total: $1568.75
Generated by PCPartPicker 2018-10-27 21:35 EDT-0400
Thoughts become things. What you hold in your mind, you will hold in your hand.
Be happy for yourself.
My rig :) :
PCPartPicker Part List: https://pcpartpicker.com/list/tX4hWD
CPU: AMD - Ryzen 7 2700X 3.7 GHz 8-Core Processor
Memory: Corsair - Vengeance RGB Pro 16 GB (2 x 8 GB) DDR4-3200 Memory
Storage: Samsung - 860 Evo 500 GB 2.5" Solid State Drive
Storage: Seagate - Barracuda 2 TB 3.5" 7200RPM Internal Hard Drive
GPU: Gigabyte - GeForce GTX 1080 Ti 11 GB AORUS Video Card
Case: Fractal Design - Meshify C ATX Mid Tower Case
Power Supply: SeaSonic - FOCUS Plus Gold 650 W 80+ Gold Certified Fully Modular ATX Power Supply
Operating System: Microsoft - Windows 10 Home OEM 64-bit
Monitor: AOC - G2770PQU 27.0" 1920x1080 144 Hz Monitor
Keyboard: Corsair - K70 RGB RAPIDFIRE Wired Gaming Keyboard
Mouse: Corsair - Sabre RGB Wired Optical Mouse
Custom: Beyerdynamic DT 770 PRO, 250 ohms
https://linustechtips.com/topic/987973-input-for-my-build-list/
I see no problems, other than the fact you didn’t put an EVGA PSU lol. I’m assumin you already have a mass storage drive? And you can always save $50 on a 2700. Your choice though, a 2700X is basically a semi-binned 2700
edit: if you want to spend $30 more you can get a 500GB Samsung 860 Evo
My Build, v2.1 --- CPU: i7-8700K @ 5.2GHz/1.288v || MoBo: Asus ROG STRIX Z390-E Gaming || RAM: 4x4GB G.SKILL Ripjaws 4 2666 14-14-14-33 || Cooler: Custom Loop || GPU: EVGA GTX 1080 Ti SC Black, on water || PSU: EVGA G2 850W || Case: Corsair 450D || SSD: 850 Evo 250GB, Intel 660p 2TB || Storage: WD Blue 2TB || G502 & Glorious PCGR Fully Custom 80% Keyboard || MX34VQ, PG278Q, PB278Q
Audio --- Headphones: Massdrop x Sennheiser HD 6XX || Amp: Schiit Audio Magni 3 || DAC: Schiit Audio Modi 3 || Mic: Blue Yeti
[Under Construction]
My Truck --- 2002 F-350 7.3 Powerstroke || 6-speed
My Car --- 2006 Mustang GT || 5-speed || BBK LTs, O/R X, MBRP Cat-back || BBK Lowering Springs, LCAs || 2007 GT500 wheels w/ 245s/285s
The Experiment --- CPU: i5-3570K @ 4.0 GHz || MoBo: Asus P8Z77-V LK || RAM: 16GB Corsair 1600 4x4 || Cooler: CM Hyper 212 Evo || GPUs: Asus GTX 750 Ti, || PSU: Corsair TX750M Gold || Case: Thermaltake Core G21 TG || SSD: 840 Pro 128GB || HDD: Seagate Barracuda 2TB
R.I.P. Asus X99-A motherboard, April 2016 - October 2018, may you rest in peace. 5820K, if I ever buy you a new board, it'll be a good one.
https://linustechtips.com/topic/987973-input-for-my-build-list/#findComment-11901206
Seasonics focus lineup psus are good
PC: CPU: i5-9600k - CPU Cooler: be quiet! Dark Rock Pro 4 - GPU: Sapphire Radeon RX 5700 XT 8GB GDDR6 - Motherboard: ASRock - Z370 Extreme4 - RAM: Team - T-Force Delta RGB 16 GB DDR4-3000 - PSU: Corsair - TXM Gold 550 W 80+ Gold Certified Semi-Modular ATX Power Supply - Case: Thermaltake - Core G21 TG
https://linustechtips.com/topic/987973-input-for-my-build-list/#findComment-11901214
I know, I was just a bit confused why he said he was getting EVGA and listed SeaSonic
https://linustechtips.com/topic/987973-input-for-my-build-list/#findComment-11901223
If you meant to type Seasonic psu, excellent choice. If you meant to change the psu in the build list, what model?
I don't believe Corsair Vengeance RGB Pro memory is compatible with the motherboard's Aura Sync lighting control.
https://linustechtips.com/topic/987973-input-for-my-build-list/#findComment-11901233
oh HA
https://linustechtips.com/topic/987973-input-for-my-build-list/#findComment-11901238
This looks great. I prefer trident Z rgb ram but the Corsair ram is good too.
It is, the Asus forum has a discussion about it.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/987973-input-for-my-build-list/#findComment-11901255
By chance, do you have a link? I could not find anything positive.
I know the Vengeance RGB is compatible, but Corsair does not include Aura Sync with Mystic Light and RGB Fusion on the Vengeance RGB Pro web page.
https://linustechtips.com/topic/987973-input-for-my-build-list/#findComment-11901271
Primary PC:
PSU tier list
https://linustechtips.com/topic/987973-input-for-my-build-list/#findComment-11901303
Thx boys and girls!! Quick responses!!
Yes, I mixed up my PSUs. I was about to buy this (((https://www.newegg.com/Product/Product.aspx?Item=N82E16817438093&ignorebbr=1))) because it's on sale for the same price as a 650w ;) should I scratch that and go for a Seasonic?
I'm gonna overclock everything eventually which is why I have the 2700x... but I'm starting out with a stock cooler on the Ryzen for a bit. If I were to get a cooler right away, I'd get the White Cryorig R1 Universal... matches everything and looks coolio.
I have corsair peripherals, hence the ram.
I do have a mass storage drive... I'm gonna start from scratch and sell my old 500 dollar pc :)
My rig :) :
https://linustechtips.com/topic/987973-input-for-my-build-list/#findComment-11901315
4 minutes ago, fasauceome said:
The memory modules in the video are Vengeance RGB, not Vengeance RGB Pro.
My personal preference is the Seasonic Focus Plus Gold. The G3 is a good unit buy hardware.info test data indicates that it can be louder than the Focus Plus Gold and RMx.
https://linustechtips.com/topic/987973-input-for-my-build-list/#findComment-11901328
Can't I use iCUE to control the sticks? I saw somewhere people were using them with iCUE... https://rog.asus.com/forum/showthread.php?104964-Corsair-Vengeance-RGB-Pro-and-AURA it looks like there you can't sync the mobo+ram but you can sync ram+peripherals... I don't mind.
and how MUCH louder? Because right now with my 4 10 dollar fans it's like a spaceship. I'm pretty used to it. Speaking of fans, what are some nice ones for a good price? I don't need RGB... but If I got rgb I'd get Corsair... I'm gonna need a sponsor soon lol
My rig :) :
https://linustechtips.com/topic/987973-input-for-my-build-list/#findComment-11901350
Sure, iCUE should work for all compatible components. However, it will not be able to control any RGB on the motherboard and I suspect it will not be able to control any RGB attached through the motherboard RGB headers. As a result you will not be able to sync motherboard RGB. Instead of using motherboard RGB headers you can use a Corsair Commander Pro.
https://us.hardware.info/category/21/power-supplies/testresults?products[]=376906&specId=10456&tcId=307
If you don't need RGB fans, beQuiet Silentwings 3 PWM are pretty good. Of course Noctua fans are good, but ugly.
https://linustechtips.com/topic/987973-input-for-my-build-list/#findComment-11901364
So let's say I don't want to spend 70 dollars on that, should I not get this fancy of ram? It actually seems like its pretty low cost for its speed and rgb stuff. I'm not sure of anything that equals it. let me know what you think. EDIT:   Ripjaws V series 3200Mhz 14 cas is boring, but the cheapest available.
and that test result is helpful. thx. Should I lose the 100w and go to Seasonic for the same price, or keep the noise and EVGA and gain the 100w?
My rig :) :
https://linustechtips.com/topic/987973-input-for-my-build-list/#findComment-11901377
It is good and good looking memory. iCUE will be able to control it so it can be coordinated with your iCUE compatible peripherals.
You would only need something like a Commander Pro if you are getting Corsair RGB fans. There are Corsair multi fan kits that include a Lighting Node Pro, which may work for you.
Since a 650W is over 200W above the estimated maximum power draw, I would feel comfortable going with the Seasonic. But the G3 is a quality unit, so you will have to make the decision.
https://linustechtips.com/topic/987973-input-for-my-build-list/#findComment-11901403
Preciate it!!
I'll go with the quieter PSU, because I can't imagine reaching more than 650w... But, what kind of build would reach 750w to 1000watts? A workstation?
I understand what you were saying about the Lighting Node now, too. Thanks for your help!
Thanks to everyone else as well! I'm excited to get building! I'm planning on recording my build. I'll probably put it in a thread somewhere else :)
My rig :) :
https://linustechtips.com/topic/987973-input-for-my-build-list/#findComment-11901432
These days most general use and gaming systems are fine with 650W. Those that intend to heavily load their system and really push cpu and gpu overclocking probably need a bit more.
https://linustechtips.com/topic/987973-input-for-my-build-list/#findComment-11901444
