1 minute ago, FlamesFans13 said:
is everything in your computer seated properly? power cables, graphics card, USB/Display cable?
Yes Every Cable Is Seated Properly.
https://linustechtips.com/topic/987957-pc-problem/#findComment-11901053
6 minutes ago, faytleingod11 said:
have you tried unplugging everything and plugging it back in? dead bugs? popped capacitors? taking out the cmos battery, holding the power for 10 seconds with the psu off and then putting the battery back in?
Yes I Try That But Same Problem My Monitor Is No Siganl And My Keyboard And Mouse Is No Light.
https://linustechtips.com/topic/987957-pc-problem/#findComment-11901145
8 minutes ago, faytleingod11 said:
all your fans spin up? have you tried using on board graphics? ps2 mouse? different usb slots? hitting f1 on the keyboard in case your pc detected a hardware change? That last one has gotten me before after a bios update.
Yes All Of My Fans Are Working Properly And I Try Different USB Slot. But Nothing Changes.
https://linustechtips.com/topic/987957-pc-problem/#findComment-11901167
