So recently, my computer has been acting odd. A couple of weeks ago, stretching back as far as about 4 months ago, the computer would regularly get blue screens and would shut down before I could see any error codes. However, recently, there has been no more blue screens. Instead, the computer freezes - then both the monitor and speakers stop outputting. They're clearly still on, displaying no signal and the speakers still have the lights on, but they just don't work. The keyboard and mouse also stay active, however I can't tell if they're working because the screens are off. The computer itself also stays on - however, it is useless without any screens or audio. A simple fix is to restart it, but it's still an annoying issue. If anyone knows any solutions, please let me know. As you can probably tell, i'm not the most tech savvy person so I definitely need some help with this. Thanks!
https://linustechtips.com/topic/987505-strange-computer-issues/
When this happens, have you tried unplugging and plugging in the display cable?
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/987505-strange-computer-issues/#findComment-11897017
Just now, Brandon_TSGZ said:
I'll give it a try next time it happens. I use two monitors and both of them go off when this happens, so...
What's the longest amount of time you've waited for the screens to come back on without restarting?
Primary PC:
PSU tier list
https://linustechtips.com/topic/987505-strange-computer-issues/#findComment-11897030
A couple of minutes. Sometimes when my drivers have updated in the past, the screens go off so I thought it was that, so I waited a little while then realised it wasn't that at all
https://linustechtips.com/topic/987505-strange-computer-issues/#findComment-11897034
Have you updated since this started happening, or tested your PC with a loaner graphics card?
Primary PC:
PSU tier list
https://linustechtips.com/topic/987505-strange-computer-issues/#findComment-11897042
Try reseatting your GPU and RAM, and making sure all your power cables are plugged in fully.
My Build, v2.1 --- CPU: i7-8700K @ 5.2GHz/1.288v || MoBo: Asus ROG STRIX Z390-E Gaming || RAM: 4x4GB G.SKILL Ripjaws 4 2666 14-14-14-33 || Cooler: Custom Loop || GPU: EVGA GTX 1080 Ti SC Black, on water || PSU: EVGA G2 850W || Case: Corsair 450D || SSD: 850 Evo 250GB, Intel 660p 2TB || Storage: WD Blue 2TB || G502 & Glorious PCGR Fully Custom 80% Keyboard || MX34VQ, PG278Q, PB278Q
Audio --- Headphones: Massdrop x Sennheiser HD 6XX || Amp: Schiit Audio Magni 3 || DAC: Schiit Audio Modi 3 || Mic: Blue Yeti
[Under Construction]
My Truck --- 2002 F-350 7.3 Powerstroke || 6-speed
My Car --- 2006 Mustang GT || 5-speed || BBK LTs, O/R X, MBRP Cat-back || BBK Lowering Springs, LCAs || 2007 GT500 wheels w/ 245s/285s
The Experiment --- CPU: i5-3570K @ 4.0 GHz || MoBo: Asus P8Z77-V LK || RAM: 16GB Corsair 1600 4x4 || Cooler: CM Hyper 212 Evo || GPUs: Asus GTX 750 Ti, || PSU: Corsair TX750M Gold || Case: Thermaltake Core G21 TG || SSD: 840 Pro 128GB || HDD: Seagate Barracuda 2TB
R.I.P. Asus X99-A motherboard, April 2016 - October 2018, may you rest in peace. 5820K, if I ever buy you a new board, it'll be a good one.
https://linustechtips.com/topic/987505-strange-computer-issues/#findComment-11897136
38 minutes ago, Brandon_TSGZ said:
If anything I think it'll be the graphics card, it is rather old...
Well if it is, it doesn't seem like you're using it for much gaming since you've got a high powered CPU and low tier GPU, so at least replacing it won't be a bad hit to the wallet. Have you stress tested it to verify?
Primary PC:
PSU tier list
https://linustechtips.com/topic/987505-strange-computer-issues/#findComment-11897283
