Please Help w/ Connections!
Solved by WoodenMarker,
In the future, it'd probably be better to type the model names out instead of just 'this'. Links can be broken with time and it's inconvenient for anyone trying to read on mobile.
2, 3, and 4pin fans are backwards compatible.
The sata power plug and 4pin connectors are for lighting accessories.
https://www.newegg.ca/Product/Product.aspx?Item=N82E16812987031
The case has no reset button. Neither the case nor motherboard comes with an included speaker.
Moved to New Builds and Planning.
