When purchasing a CPU or simply upgrading, why is it that we are able to "overclock" a chip? Wouldn't it be easier to simply just have what we all want in the chip - speed, performance, maxed out, tip top, etc...
Why don't they sell a chip based at 3.70 which can be altered/boosted to 4 right from the get go?
What am I missing here?
https://linustechtips.com/topic/987400-unmatched-power/
its the silicon lottery most of the chips can overclock yet likely a few chips couldnt get past 3.7 so they set that as a standard (if you get what im saying)
https://linustechtips.com/topic/987400-unmatched-power/#findComment-11896076
Silicon quality.
Not all chips are created equal. By setting a conservative range they can sell x% of chips off the wafer. If they set the range higher they would get less % of chips within range.
If you're interested in a product please download and read the manual first.
Don't forget to tag or quote in your reply if you want me to know you've answered or have another question.
https://linustechtips.com/topic/987400-unmatched-power/#findComment-11896085
21 minutes ago, RonnieC said:
@Nolanrulesroblox Not entirely sure as to what you mean. I do understand that the chips come base and then we can simply alter their stats and hopefully not blow them up.... :P
well as @keskparane said not all chips are the same. so in turn they set a base clock 3.70 ghz because 99% of the cpus can reach that
22 minutes ago, keskparane said:
Silicon quality.
Edited by Guest
forgot to add something
https://linustechtips.com/topic/987400-unmatched-power/#findComment-11896104
