Corsair LL problem
Go to solution Solved by Defyant,
Yer i got this bug ages ago when i got my first set...... it actually went away.... i remember just moving them to 4,5,6 on the hub and it stopped.... i think eventually just different software fixed it  Try that first so you know if its a fan or hub.
Try this as well.
- Close iCue
- type Services in the search bar, press Enter.
- Search for CorsairService, right click it, choose Properties
- Press Stop, and in the Startup type drop-down menu, choose Manual
- Click Apply
- Reopen iCue
Howdy, So I recently purchased a triple pack of Corsair 120mm LL RGB fans and right from the start one of the fans started flickering whenever I change the colour settings to anything other than 'Static Colour'. Does anyone what could be the issue?
OHHH, SASUKE-KUN!!!!!!!!!!!!!!
https://linustechtips.com/topic/986414-corsair-ll-problem/
Try this as well.
- Close iCue
- Click Apply
- Reopen iCue
https://linustechtips.com/topic/986414-corsair-ll-problem/#findComment-11887567
