So before I get into the nuts and bolts of my quandry I just want to say what I am hoping to get is general advice on upgrading my rig, not a step by step or whatever.
Currently I have:
3930K @ 4.4GHz
Asus Rampage 4 Formula
GTX 1080Ti
480GB SSD
3TB HD
32 GB DDR3 @ 1600
So The problem I am having *I think* is that my motherboard is starting to get flaky, as they do when they get old and stuff, and my computer has started to not want to boot on the first couple tries and recently it has decided that my storage drive is an occasional drive not something that should be at hand at all times. So the question, how, with a $500 budget should I proceed? the way I see it Ill need a new mobo, cpu and ram but which to get? I primarily game on this PC so no need for "productivity" considerations.
Thanks for your help!
https://linustechtips.com/topic/985711-advice-opinions-thoughts/
Two options I would recommend is either purchasing an i5-8600k with an MSI Performance Gaming Plus (just a suggestion), or since intel's pricing is stupid rn, going with an r7 2700x paired with an MSI x470 gaming plus (still just a suggestion)
edit: I did not notice you said ram before. In that case a 2600 paired with an msi b450-a pro or the 8600k pair if you wanna spend a bit over budget
PC: CPU: i5-9600k - CPU Cooler: be quiet! Dark Rock Pro 4 - GPU: Sapphire Radeon RX 5700 XT 8GB GDDR6 - Motherboard: ASRock - Z370 Extreme4 - RAM: Team - T-Force Delta RGB 16 GB DDR4-3000 - PSU: Corsair - TXM Gold 550 W 80+ Gold Certified Semi-Modular ATX Power Supply - Case: Thermaltake - Core G21 TG
12 minutes ago, rulemd2000 said:
There's nothing much to upgrade hardware wise.
You could get an R5 2600 + MSI Tomahawk + 16GBs of DDR4 for around $500
Try and wait for Ryzen 3000 early next year if you can
but what's your monitor resolution/refresh rate?
4k 60Hz
3 minutes ago, rulemd2000 said:
4k 60Hz
For 60hz you could get by just fine on a cheap R3 2200G to get on AM4 and upgrade it to a 6/8 core 3000 series chip next year.
Only worth it if you're really starting to have issues though.
or an R5 2600 will be fine, just not much of a performance increase. It's mostly about it's price.
Upgrade to this. It'll put you on the AM4 socket that will be supported through 2020.
Type Item Price
CPU AMD - Ryzen 7 2700 3.2GHz 8-Core Processor $249.43 @ OutletPC
CPU Cooler be quiet! - Pure Rock Slim 35.1 CFM CPU Cooler $27.89 @ OutletPC
Motherboard MSI - B450-A PRO ATX AM4 Motherboard $69.99 @ B&H
Memory G.Skill - Ripjaws V Series 16GB (2 x 8GB) DDR4-3200 Memory $139.99 @ Newegg
  Prices include shipping, taxes, rebates, and discounts
  Total (before mail-in rebates) $497.30
  Mail-in rebates -$10.00
  Total $487.30
  Generated by PCPartPicker 2018-10-22 03:08 EDT-0400
Rest In Peace my old signature...                  September 11th 2018 ~ December 26th 2018
