I am looking to build my first PC as I will be graduating college in june.
Budget & Location
I am in the USA with a budget of around 1500 (including peripherals)
Aim
This will be a gaming PC. More specifically it will be for mostly RPG's, such as the witcher 3 and others. I want to be able to run most games around 90 fps on high settings.
Monitors
I don't have any monitors at the moment.
Peripherals
I will need a monitor, keyboard, and mouse.
Why are you upgrading?
It is time to get a real PC and move on from my 2014 (or 15 I'm not 100% sure) razer blade.
I know that I want to build in the nzxt h500i. Any help with a part list that I can then use to make my own would be much appreciated!
https://linustechtips.com/topic/985700-my-first-build/
If you're building at that time, I'd wait for AMD's 7nm chips. They should be out come June.
Ryzen 5 1600 @ 3.9 Ghz  | Gigabyte AB350M Gaming 3 |  PaliT GTX 1050Ti  |  8gb Kingston HyperX Fury @ 2933 Mhz  |  Corsair CX550m  |  1 TB WD Blue HDD
Inside some old case I found lying around.
https://linustechtips.com/topic/985700-my-first-build/#findComment-11879218
PCPartPicker part list: https://pcpartpicker.com/list/kvJhBb
Price breakdown by merchant: https://pcpartpicker.com/list/kvJhBb/by_merchant/
CPU: AMD - Ryzen 5 2600 3.4GHz 6-Core Processor  ($149.99 @ Amazon)
CPU Cooler: be quiet! - Dark Rock 4 CPU Cooler  ($66.99 @ SuperBiiz)
Motherboard: MSI - B450 TOMAHAWK ATX AM4 Motherboard  ($103.98 @ Newegg)
Memory: G.Skill - Trident Z 16GB (2 x 8GB) DDR4-3000 Memory  ($139.99 @ Newegg)
Storage: Samsung - 860 Evo 250GB 2.5" Solid State Drive  ($55.99 @ Amazon)
Storage: Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($58.50 @ Amazon)
Video Card: EVGA - GeForce GTX 1070 8GB SC Gaming ACX 3.0 Video Card  ($359.99 @ Amazon)
Case: NZXT - H500i (White) ATX Mid Tower Case  ($99.00 @ B&H)
Power Supply: Corsair - CXM 650W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($59.90 @ Amazon)
Keyboard: SteelSeries - Apex M750 Wired Gaming Keyboard  ($109.99 @ Amazon)
Mouse: SteelSeries - Rival 600 Wired Optical Mouse  ($71.59 @ Amazon)
Total: $1275.91
I'm not very knowledgeable about monitors tho...so I'll leave that up to you.
https://linustechtips.com/topic/985700-my-first-build/#findComment-11879359
https://linustechtips.com/topic/985700-my-first-build/#findComment-11879765
