Fix FPS Drops
Go to solution Solved by Spotty,
Yeah. CoD BO4 really needs more than 8GB of RAM. Upgrading to 16GB will help a lot in AAA games.
Quote
Recommended:
  • OS: Windows 10 64 Bit
  • CPU: Intel Core i7 4770k or AMD equivalent
  • RAM: 12GB RAM
  • HDD: 40GB HD space
  • Video: Nvidia GeForce GTX 970 / GTX 1060 6GB or AMD Radeon R9 390 / AMD RX 580
  • DirectX: Version 11.0 compatible video card or equivalent
  • Network: Broadband Internet connection
  • Sound Card: DirectX Compatible
Hello,
So when I'm playing games I usually get 100+ FPS. But here and there it drops to 30 for a split second which then leads to me dying or raging lol.
I was wondering what part I should upgrade to fix this issue. RAM or CPU.
My CPU is a Ryzen 3 2200g, and I have 8gb's of RAM.
My graphics card is a 1060 6gb so it obviously cannot be this.
I am really wanting to know if I should get more RAM to fix the FPS drops or upgrade my CPU.
Thanks, Ben.
CPU: AMD Ryzen 7 3700X | Mobo: Asrock AB350 Pro4 | Ram: G.Skill Trident Z (2x8GB) DDR4-3200 | Storage: Intel 545s Series 256GB M.2 (SATA) SSD/Western Digital WD Blue 1TB/Samsung 860 EVO 500GB SSD | GPU: Zotac Geforce GTX 1060 6GB AMP! Edition | Case: NZXT S340 Black Case | PSU: Corsair HX750 | Operating System: Windows 11 Pro | Keyboard: Ducky One 2 Mini White MX Brown | Mouse: Logitech G Pro Wireless | Headphones: Astro A50 Gen 2 | Mic: Rode NT-USB | IEMS: KZ ZSN Pro X
https://linustechtips.com/topic/985058-fix-fps-drops/
What games are you playing?
What settings in the game?
What monitor are you using?
It's most likely your RAM.
https://linustechtips.com/topic/985058-fix-fps-drops/#findComment-11874060
Bo4, All low-medium
1080p.
So I should get RAM? Will do.
Thanks
https://linustechtips.com/topic/985058-fix-fps-drops/#findComment-11874064
Quote
Recommended:
  • RAM: 12GB RAM
https://linustechtips.com/topic/985058-fix-fps-drops/#findComment-11874066
Just now, black0utm1rage said:
In very CPU intensive games this could be a problem since this isn't exactly a very powerful cpu. The lags you observe could be due to inconsistent frametime pacing
I plan on upgrading in the future. At the moment I'm going to buy RAM as it's affordable but I will be upgrading my CPU.
https://linustechtips.com/topic/985058-fix-fps-drops/#findComment-11874068
Also at least a 4770k or equivalent. I'd say that a Ryzen 3 is not equally powerful as a 4770k...
Honestly, it's probably not that far off. They're both 4c/8t CPUs with base clocks of 3.5GHz. Remember the 4770k is more than 5 years old now.
https://linustechtips.com/topic/985058-fix-fps-drops/#findComment-11874071
I'm gonna be getting a Ryzen 7 2700x probs in two or so months so yeah.
https://linustechtips.com/topic/985058-fix-fps-drops/#findComment-11874072
Looked up some benchmarks. An overclocked (3.9 Ghz) R3 1200 is only about on par with a 3770 non-k. So the 4770k will def. still be a lot faster.
https://linustechtips.com/topic/985058-fix-fps-drops/#findComment-11874085
