when will 1809 be re-released?
Solved by Sakkura,
Just now, firelighter487 said:did they? because i'm not getting it...
That's because it's a rollout rather than an old-school launch. They update a small number of systems, then update a larger number of systems, then an even larger number... while checking each step of the way if issues are appearing. That way they minimize the impact if there does happen to be a problem with the update.
