troubleshooting Help! My computer won't boot!
Solved by ZaKnight,
Hey guys! I just wanted to let you know that after some more testing I figured out that I simply had a fualty processer. I installed a brand new core i7 8700k and it booted immediately. Thanks so much for all your help guys! The information you gave me helped a lot to narrow down the problems much sooner! I'll definitely come to these forums again if I have any other tech issues, thanks again guys!
