Sorry if this is the wrong place to post this, but i was hoping to get some help on building a gaming pc.
Basically i want to run forza horizon 4 on extreme settings at 60+fps...
I am completly new to building pc's as this will be my first build, i was hoping somebody would be willing to "build" me a setup to match my requirements.
I'd like to stay as cheap as possible, but i know im asking for a lot.
Thank you to anybody that responds:)
https://linustechtips.com/topic/984522-build-help/
Define cheap? Can you give us a general range of budget you'd like to stay within?
Where are you located? What country, currency, etc.?
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
https://linustechtips.com/topic/984522-build-help/#findComment-11869355
If you don't need a monitor, keyboard, etc.
CPU: AMD - Ryzen 5 2600 3.4GHz 6-Core Processor  ($149.99 @ Amazon)
Motherboard: Asus - PRIME B450-PLUS ATX AM4 Motherboard  ($104.81 @ Amazon)
Memory: G.Skill - Ripjaws V Series 16GB (2 x 8GB) DDR4-3200 Memory  ($124.99 @ Newegg)
Storage: Crucial - MX500 250GB 2.5" Solid State Drive  ($54.95 @ Adorama)
Storage: Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($58.89 @ OutletPC)
Video Card: EVGA - GeForce GTX 1060 6GB 6GB SC GAMING Video Card  ($239.00 @ B&H)
Case: Cougar - MX340 ATX Mid Tower Case  ($44.32 @ Amazon)
Power Supply: Corsair - TXM Gold 550W 80+ Gold Certified Semi-Modular ATX Power Supply  ($43.98 @ Newegg)
Total: $820.93
Generated by PCPartPicker 2018-10-18 17:05 EDT-0400
or maybe something with a bit more power
Video Card: EVGA - GeForce GTX 1070 Ti 8GB SC GAMING ACX 3.0 Black Edition Video Card  ($409.99 @ Newegg Business)
Total: $991.92
If you need a monitor, keyboard, mouse, etc.
Monitor: BenQ - GL2460HM 24.0" 1920x1080 60Hz Monitor  ($127.99 @ Amazon)
Keyboard: Redragon - S101 Wired Gaming Keyboard w/Optical Mouse  ($29.99 @ Amazon)
Total: $978.91
Generated by PCPartPicker 2018-10-18 17:07 EDT-0400
Prior Build Log/PC:
https://linustechtips.com/topic/984522-build-help/#findComment-11869377
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/984522-build-help/#findComment-11869380
For sure buy the gpu used no point in buying a new gpu with used prices being so good
R7 2700x (4.3ghz), Gtx Titan Xp Galactic Empire (Watercooled), 2x8 Gskill Trident 3200mhz, Asus Crosshair VII Hero Wifi, Corsair 900D, SAMSUNG 960 PRO M.2 256gb, Samsung 850 evo 500gb, 4x3tb 7200rpm Segate Barracudas in Raid 10 EKWB Custom Loop, Corsair AX1500i Power supply
https://linustechtips.com/topic/984522-build-help/#findComment-11869384
-Moved to New Builds and Planning-
https://linustechtips.com/topic/984522-build-help/#findComment-11869420
