Well this might be a little too easy to be an actual question, but I'm learning how to use R studio and it's a bit hard to get to know how to use some functions/commands. Basically I have 2 columns,  the first one has the data I want to plot and the other one has labels. How can I sort the data on my dataset to I only use the data from the first column acording to the label I pick?
(edit)
I think I was being to vague, attached an image, basically I want to pick evvery element in the column 1  matching protein in column 2, I am sure I am using "subset()" the wrong way
Edited by Habby
adding more information
https://linustechtips.com/topic/983904-need-some-help-with-r/
a <- seq(1,10,1)
b <- rep(c("protein","somethingelse"),5)
lala <- matrix(nrow=10,ncol=2,data=c(a,b),byrow=FALSE)
lala[which(lala[,2]=="protein"),]
lala[which(lala[,2]=="protein"),][,1]
The only line interesting are the last two.
with which you find the rows that only have protein in column 2 and then using that to retrieve only the first column in the last line for only the data
edit: Using subset
subset(lala, lala[,2] == "protein")
for only data column use:
subset(lala, lala[,2] == "protein")[,1]
change lala to your dataobject name
https://linustechtips.com/topic/983904-need-some-help-with-r/#findComment-11864030
11 hours ago, Helibert said:
a <- seq(1,10,1)
edit: Using subset
ty a lot for your help man, I'm guessing I can use this for every column and row I want , this was really helpful
https://linustechtips.com/topic/983904-need-some-help-with-r/#findComment-11865739
