When starting a topic like this it's usually helpful and nice to list your specs. Is the below configuration still accurate?
CPU
Pentium G4560
Motherboard
Msi B250m PRO-VD
RAM
1x8 Kingston Hyper X fury
GPU
E.V.G.A Gforce Gtx 1050
Case
V.I.V.O Smart micro-atx
Storage
kingston ssd now uv400 120 gb
PSU
E.V.G.A 430w
I would go into the BIOS and have a look at the boot order first of all, even with 1 drive sometimes it can cause issues and tries to boot into locations that don't have Windows installed.
If it's ok, may I also ask what program you were installing?
https://linustechtips.com/topic/983860-someone-help-me/#findComment-11862848
  Hide contents
CPU
Pentium G4560
Motherboard
Msi B250m PRO-VD
RAM
GPU
Case
Storage
PSU
E.V.G.A 430w
Audacity
https://linustechtips.com/topic/983860-someone-help-me/#findComment-11862855
  Reveal hidden contents
CPU
Pentium G4560
Motherboard
Msi B250m PRO-VD
RAM
GPU
Case
Storage
PSU
E.V.G.A 430w
This poped up after i put my ssd as the 1
https://linustechtips.com/topic/983860-someone-help-me/#findComment-11862856
CPU
Pentium G4560
Motherboard
Msi B250m PRO-VD
RAM
GPU
Case
Storage
PSU
E.V.G.A 430w
My easiest route is to format ive tried every trick in the book
https://linustechtips.com/topic/983860-someone-help-me/#findComment-11862860
Aside from some sort of hardware failure, if you're happy to do that that will most-likely solve your problem.
https://linustechtips.com/topic/983860-someone-help-me/#findComment-11862870
1 minute ago, Microsoft Master said:
I did i need to backup my data more often.
I'm in the same boat there. I'm looking a buying a 1TB or 2TB portable drive and just manually back it up every month or so. I also do smaller backups on Google Drive and all of my photos are automatically backed up to Google Photos.
https://linustechtips.com/topic/983860-someone-help-me/#findComment-11862904
58 minutes ago, Microsoft Master said:
So i restarted my pc because i installed a new program and this screen popped up can someone help me, i tried all the options it gave me
when does that ''choose an option'' screen show up? does it show up when you start your PC? go to advanced and perform either a system repair or a system restore.
i7-8700K l MSI RX 580 8GB ARMOR MK2 MSI - Z370 KRAIT GAMING l G.Skill Ripjaws 16GB DDR4-3200 l Inland 120GB SSD + 1TB HDD Scythe FUMA Rev. B l EVGA 600W 80+ Bronze Certified l Asus VG248QE 144Hz l Zowie FK2 Audio-Technica ATH-AD500X l Phanteks P300 Tempered Glass l Corsair Gaming K70 RAPIDFIRE l windows 10.
https://linustechtips.com/topic/983860-someone-help-me/#findComment-11862950
I think the user has already tried both those methods and the thread is now resolved the user reinstalled Windows.
There's plenty of others out there we can that still help. ?
https://linustechtips.com/topic/983860-someone-help-me/#findComment-11863009
Thank god i have usb wifi too because every time this happens i would have to being this to the other side of my house
https://linustechtips.com/topic/983860-someone-help-me/#findComment-11864240
