With the holidays rapidly approaching ( and my Bday) I have decided to build a PC for gaming. I will also be using Photoshop a lot for school and some of the games I play. Included is the build I have come up with on my own using LTT and a few other channels to look into parts. My budget is around 400-600 usd with a case. I like the case I have selected but if there is a better rgb option around that price point I will most likely switch the case. Thanks for looking at the post and helping with my first build.
https://linustechtips.com/topic/983859-first-pc-build/
Looks good except I would recommend getting at least a bronze certified psu.
PC: CPU: i5-9600k - CPU Cooler: be quiet! Dark Rock Pro 4 - GPU: Sapphire Radeon RX 5700 XT 8GB GDDR6 - Motherboard: ASRock - Z370 Extreme4 - RAM: Team - T-Force Delta RGB 16 GB DDR4-3000 - PSU: Corsair - TXM Gold 550 W 80+ Gold Certified Semi-Modular ATX Power Supply - Case: Thermaltake - Core G21 TG
https://linustechtips.com/topic/983859-first-pc-build/#findComment-11862829
CPU: AMD - Ryzen 3 2200G 3.5GHz Quad-Core Processor  ($98.79 @ SuperBiiz)
Motherboard: MSI - B450-A PRO ATX AM4 Motherboard  ($69.99 @ B&H) much better for the same price.
Memory: G.Skill - Aegis 8GB (1 x 8GB) DDR4-3000 Memory  ($62.89 @ OutletPC)
Storage: MyDigitalSSD - BP5e Slim 7 240GB 2.5" Solid State Drive  ($39.99 @ Amazon)
Storage: Seagate - Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($43.95 @ Amazon)
Video Card: Gigabyte - Radeon RX 570 4GB AORUS 4G Video Card  ($160.00 @ Newegg)
Case: Cougar - MX330 ATX Mid Tower Case  ($41.99 @ B&H)
Power Supply: Corsair - CX (2017) 750W 80+ Bronze Certified ATX Power Supply  ($39.99 @ Newegg)
Total: $557.59
Generated by PCPartPicker 2018-10-16 19:55 EDT-0400
https://linustechtips.com/topic/983859-first-pc-build/#findComment-11862833
Rest In Peace my old signature...                  September 11th 2018 ~ December 26th 2018
https://linustechtips.com/topic/983859-first-pc-build/#findComment-11862839
