Using SSD
Solved by SSD Sean,
Sure you cloned over the OS properly? Boot partition/files included? Sounds like there is no boot data on the SSD and the motherboard is detecting it on the HDD only and booting off that when the SSD shows nothing. What software did you use? What SSD and system is it? Sometimes I've had AOMEI Backupper Software say it cloned, but didn't. I hear good things about macrium reflect, but I usually use Acronis True Image.
