Case help
Go to solution Solved by H3LLSMAN,
In the description it says the following
" 30x RGB LED front fascia lighting-zone and four Corsair LL120 RGB 120mm fans provide complete RGB customization. " for the newegg edition
and
" 30x RGB LED front fascia lighting-zone and two CORSAIR HD120 RGB 120mm fans provide complete RGB customization." for the RGB edition
 so the price difference is for the included fans.
I'm going to be buying a new case called Corsair Carbide Series SPEC-OMEGA RGB Mid-Tower Tempered Glass Gaming Case on Newegg but then there is Newegg edition and I don't see the differences. (except price)
so what is the actual difference?
link: https://www.newegg.com/global/uk/Product/Product.aspx?reviews=all&item=N82E16811139124
https://linustechtips.com/topic/982463-case-help/
uhh just found out there are extra fans that it I think uhh how do you delete topic
https://linustechtips.com/topic/982463-case-help/#findComment-11850462
and
Thermatake Tower 900 Build
Intel® Core™ i7-7700K @5.3GHz -2AVX / ROG MAXIMUS IX APEX + EK-FB ASUS M9A Monoblock
ROG-POSEIDON-GTX1080TI 11Gb @2114MHz/5780Mhz / DIMM.2 970 EVO 2TB NVMe PCIe M.2 x2 RAID 0
EVGA SuperNOVA 1600 P2 80+ PLATINUM / Hisense 65" H9 Plus 4k HDR
https://linustechtips.com/topic/982463-case-help/#findComment-11850464
But it does have a 20 dollar discount rebate card for the regular RGB version, I am not sure what the cost of the included fans make it worth it but might want to do the math on that and go from there.
https://linustechtips.com/topic/982463-case-help/#findComment-11850466
