Hi!
I recently bought one of those razer keypads, and kinda happy with it. but there is a problem, i also have an old razer mice but it does not come up in the new razer synapse program. i can only edit it on the old one which does not want to for some reason to connect or talk to the new program. i dont know whats wrong, and ive done some googling but nothing that comes up helps. Any suggestions?
Thanks!
https://linustechtips.com/topic/981419-razer-synapse-help/
Hi,
It happend to me something like that.
Razer Synapse 3 (most recent new version) does only support some devices (the most new) like for example, I have a razer kraken chroma 7.1 and there is a new version of that headset razer kraken chroma 7.1 V2, and razer synapse 3 works for the V2 version but does not support mine.
The razer synapse 2 does support that older devices, I do not know if the new devices are supported on this version synapse 2, but I would probably give it a try.
Is it stupid that new version the most recent synapse is only for new devices.
Hope it Helps.
Trokato Out
https://linustechtips.com/topic/981419-razer-synapse-help/#findComment-11840554
3 hours ago, leander17king said:
Hi!
Thanks!
What mouse and keypad do you have?
An older Razer mouse may incompatible with Synapse 3.
"Make sense? Oh, what fun is there in making sense?"
-Discord
https://linustechtips.com/topic/981419-razer-synapse-help/#findComment-11841076
3 hours ago, Trokato said:
Hi,
Hope it Helps.
Trokato Out
It’s not necessarily that Synapse 3 won’t support these devices at all. Synapse 3 is in beta, with limited support for devices. They should be adding older ones soon.
it's time
https://linustechtips.com/topic/981419-razer-synapse-help/#findComment-11841079
Yap, Probably when this version replace other versions will support all devices, but now is limited.
Check this link to see the supported devices for synapse 3:
https://www.razer.com/synapse-3
https://linustechtips.com/topic/981419-razer-synapse-help/#findComment-11843657
