So, here's the problem. I,ve just build a brand new pc with an xfx rx 580. everything seems good, only one thing my current resolution is at 1360x720 because I can't go higher. If I want to use a higher resolution, I can't because its just glitched out. I'm using an old RCA tv as my monitor, I had a PS4 before and it was and still is running correctly at 1920x1080p without any problems. I've tried using older graphics card drivers and it isn't working aswell. I doon't know what to do.20181010_063910.thumb.jpg.d852326a85722fb42e221aec1ad67dfd.jpg
https://linustechtips.com/topic/981384-problem-with-my-display/
how are you connecting your GPU to the monitor?
HDMI would be the way to go if it is a TV.
if you are using the RCA connectors there are a lot of bandwidthh limitations you are running into. then you are limited in resolution and refresh-rate.
Positive Mental Additude!
Just another Tired IT guy...
https://linustechtips.com/topic/981384-problem-with-my-display/#findComment-11840260
I am using HDMI, when I mean RCA, I mean my tv's brand
https://linustechtips.com/topic/981384-problem-with-my-display/#findComment-11840269
16 hours ago, popodawa said:
I did try yesterday,  doesn't work. I just pray it isn't a defective GPU problem
if the gpu was defective it wouldn't output at all , and you have tried another gpu and that didn't fix is as well.
any chance you can test it on another display?
https://linustechtips.com/topic/981384-problem-with-my-display/#findComment-11843418
