I have a lot of problems with audio on my laptop first sometimes my speaker doesn't work and then I have to disconnect them in device manager, reboot and then it finally works second there is no way to use an external microphone even with a USB audio adapter and the Realtek HD audio manager doesn't help (it was pre-installed) and it doesn't even let me chose the audio output (my laptop is the Asus r752sv-ty021t)
https://linustechtips.com/topic/981176-problems-with-laptops/
Download the latest audio drivers from Asus's website. Uninstall the current audio driver, reboot, install the new drivers, and reboot again. See if that clears it up.
As for the microphone, you may want to make sure its the default recording device. USB Microphones bypass your laptops sound processor altogether, so that is an unrelated issue.
QUOTE ME IF YOU WANT A REPLY!
PC #1
Ryzen 7 3700x@4.4ghz (All core) | MSI X470 Gaming Pro Carbon | Crucial Ballistix 2x16gb (OC 3600mhz)
MSI GTX 1080 8gb | SoundBlaster ZXR | Corsair HX850
Samsung 960 256gb | Samsung 860 1gb | Samsung 850 500gb
HGST 4tb, HGST 2tb | Seagate 2tb | Seagate 2tb
Custom CPU/GPU water loop
PC #2
Ryzen 7 1700@3.8ghz (All core) | Aorus AX370 Gaming K5 | Vengeance LED 3200mhz 2x8gb
Sapphire R9 290x 4gb | Asus Xonar DS | Corsair RM650
Samsung 850 128gb | Intel 240gb | Seagate 2tb
Corsair H80iGT AIO
Laptop
Core i7 6700HQ | Samsung 2400mhz 2x8gb DDR4
GTX 1060M 3gb | FiiO E10k DAC
Samsung 950 256gb | Sandisk Ultra 2tb SSD
https://linustechtips.com/topic/981176-problems-with-laptops/#findComment-11838107
the latest aoudio driver on sus website is from 2016 and i have the latest driver was pre installed
https://linustechtips.com/topic/981176-problems-with-laptops/#findComment-11850159
