Hello,
Recently just installed my new MSI Trio 2080 with the NVLink bridge and both cards are showing up in GPU-Z, Device Manager, Nvidia Control Panel etc but under '3D Settings' and 'Configure Surround, PhysX' it doesn't show anything to do with SLI.
Motherboard - Maximus x Hero running at latest BIOS
Please help :)
https://linustechtips.com/topic/981069-need-help-with-nvlink/
4 minutes ago, md0302 said:
Hello,
Please help :)
Make sure you're on the latest driver. Maybe even give the system a reboot with the bridge installed and see if anything shows up.
https://linustechtips.com/topic/981069-need-help-with-nvlink/#findComment-11837113
I agree, make sure you have the newest drivers since NVlink before was used in professional applications and probably won't show up as SLI until you have the most recent drivers.
Rainbow Barf
CPU: i7-12700K GPU: RX 6800 XT RAM: 64GB DDR4 Storage: 2TB NVME SSD RAID - 1TBx2 NVME SSD - 8TB HDD
Lenovo Legion Pro 5i
CPU: i7-12700H GPU: RTX 3070 Ti RAM: 32GB DDR5 Storage: 1TB + 1TB SSDs
https://linustechtips.com/topic/981069-need-help-with-nvlink/#findComment-11837118
1 minute ago, md0302 said:
Hey guys, thanks for the replies, i've got the latest 2080 drivers installed and it still doesn't seem to work. very weird
Could be a motherboard issue.
Check to see if ASUS has a BIOS update. Some Other ASUS users are reporting the same thing. They using the Zenith Extreme though.
https://linustechtips.com/topic/981069-need-help-with-nvlink/#findComment-11837135
