My setup:
3770k
Rampage 5 formula
16gb trident x ram
Corsair h100i
Nzxt phantom 820 case
1200w antec Psu
2x gtx780
3x 1080p monitors
Ok I'm trying to overclock my CPU and I'm using prime95 as my stress test.
For the last few months I have been running CPU at 4.5ghz and 1.245v and never hit over 90deg.
Last week my computer crashes a few times during bf4 so I reset my overclock.
So first off my idle temps are hovering at 50deg
When I run small fft @4.4Ghz 1.25v I get temps of 90-100degs within first few mins.
Even during bf4 at at the setting temps hit 90deg.
This is very weird and the only thing I can think of is that I damaged my chip.
One thing I was wondering is that since it's summer here does ambient temp make idle temps run higher ? And do I need to reseat my cooler?
Thanks in advance
https://linustechtips.com/topic/98098-cpu-water-cooling-help/
are your fans even running? O.o maybe reseat the h100i and get new thermal paste.
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/98098-cpu-water-cooling-help/#findComment-1312249
No such thing as the Rampage V exists, I take it you mean Maximus V Formula. As for your temperatures the ambient temperature does affect both idle and load temperatures. What is your ambient temperature? What temps do you get with stock clocks? What TIM are you using?
https://linustechtips.com/topic/98098-cpu-water-cooling-help/#findComment-1312250
whats the config of the h100i and what mode are the fans set on when you run your computer normally ( quiet, balanced or performance ) ?
Current Build :
CASE: Fractal Design R4 w/Window CPU: Intel 4930K,  RAM: 16GB Ripjaws Z 2133Mhz  Cooling: H100i  MotherBoard: Asus P9x79 Pro , PSU: CS750M   Storage: 2x Samsung 840 Pro 256Gb , 1Tb Seagate Barracuda, 500GB WD Black,  Graphics: Gigabyte GTX 780 Windforce 3GB,  Monitors: AOC G2460PG ( G sync monitor), Edge10 24" 1080p , 24" 1680*1020p monitor ( LCD)  Microphone: Blue Yeti  Keyboard: Cougar 700k  Phone: Samsung Note 3  Headphones: Sennheiser HD598
Laptop:
 CPU:
4710MQ  Ram: 8GB 1600MHz Storage:120Gb 840 Evo + 1Tb 5400Rpm HDD  Graphics: GTX 850M 2GB   Screen: 1080p IPS
https://linustechtips.com/topic/98098-cpu-water-cooling-help/#findComment-1312265
Your pump on the h100i most likely stopped working.
CPU: Intel i7-3770k at 4.8Ghz  CPU Cooling: 320mm UT60  Motherboard: MSI Z77A-GD55  RAM: G.Skill Ripjaws X Series 16GB 2133Mhz (2x8GB)  SSD: Intel 330 Series 120GB  HDD: WD 1TB Caviar Green  GPU: EVGA GTX 780 x2  Sound Card: Creative Recon3D  PSU: Raidmax RX-1000AE 1000W  Case: Arc Midi R2  Monitor: Benq XL2420T at 129Hz  OS: W8 64Bit  Keyboard: Razer Blackwidow 2013 Ultimate  Mouse: Logitech MX518  Mousepad: Steelseries QCK+  Headset: Turtlebeach X12 (Temp.)
https://linustechtips.com/topic/98098-cpu-water-cooling-help/#findComment-1312993
Ahh maybe. I just checked on corsair link and it has 2156 on the pump icon. Could that be a false reading. And the h100i temp goes up to 55degrees in during prime95. Not sure if that is relevant. il contact corsair and see if I can get a replacement anyway
https://linustechtips.com/topic/98098-cpu-water-cooling-help/#findComment-1313402
