Should I just use a standard Ryzen 2700 or go order a Threadripper X or a i9 9900X I mean no one is going to see the cpu unless I keep CPU z open
Best Value Build List
Budget 1080p System (RGB) https://pcpartpicker.com/list/7v2Lmq - (this build comes with two free games with the RX 570)
https://linustechtips.com/topic/980942-display-system-for-pc-corner/
Um... what? I don't understand this post?
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
Im building a display system in the PC corner in my uncle's hardware shop as I do builds for people
I was wondering should I go order a intel 9900X or a threadripper or just go with a 2700 which I have in stock
Like a demo system?
Just now, Galion said:
something like that
Honestly I don't think they would core if it's not a Core i9 or something. As long as it performs well in the games being demoed (if you're going to have any available) and the build looks clean and nicely done.
Ok; thank you I guess I''ll do a standard build for the display then
do a build with gaming-oriented parts(i.e 8700k etc) instead of things like threadripper because usually showing off high fps would attract more interest than high cinebench scores to a guy who doesn’t know too much about computers
Aren't they the same? The faster the cine bench finishes the higher the fps right?
Not necessarily. Many games are only optimized to use 4-8 cores, whereas cinebench uses all cores. So single core performance is usually what determines fps in games. Usually CPUs with high core count like xeons and threadrippers have lower single core performance than a i7 or ryzen 7.(i9s have similar single core performance to an i7-8700k, but are slightly weaker). So right now, the best gaming cpu on the market is the i7-8700k, followed by the ryzen 7 2700x and the i5-8400. as they all have strong single core performance.
Not when games can't use all 32 cores, and 24/32 sit idle. The trade-off with more cores is lower CPU frequency, to keep the rated TDP down, resulting in lower FPS.
i9-7980XE has a base clock of 2.6GHz.
That won't give you much FPS in games, running at stock.
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
3 minutes ago, -rascal- said:
Not when games can't use all 32 cores, and 24/32 sit idle. The trade-off with more cores is lower CPU frequency, to keep whichever DP down, resulting in lower FPS.
Oh OK now I understand thanks
Sorry, meant to say "to keep the rated TDP down." Auto-complete on mobile...
AMD Ryzen 9000 Rig
AMD Ryzen 5000 Rig
  • AMD R7-5800X
Yup I know thanks for the edits anyway
