lmao wut
PC: CPU: i5-9600k - CPU Cooler: be quiet! Dark Rock Pro 4 - GPU: Sapphire Radeon RX 5700 XT 8GB GDDR6 - Motherboard: ASRock - Z370 Extreme4 - RAM: Team - T-Force Delta RGB 16 GB DDR4-3000 - PSU: Corsair - TXM Gold 550 W 80+ Gold Certified Semi-Modular ATX Power Supply - Case: Thermaltake - Core G21 TG
https://linustechtips.com/topic/980755-help-me/#findComment-11833954
3 minutes ago, Dragi said:
Ryzen 2700X with  Name Mainbord B450 , X370 , something :C ?
Not sure what you're asking here. Can you please retype the question?
Fine you want the PSU tier list? Have the PSU tier list: https://linustechtips.com/main/topic/1116640-psu-tier-list-40-rev-103/
Stille (Desktop)
Ryzen 9 3900XT@4.5Ghz - Cryorig H7 Ultimate - 16GB Vengeance LPX 3000Mhz- MSI RTX 3080 Ti Ventus 3x OC - SanDisk Plus 480GB - Crucial MX500 500GB - Intel 660P 1TB SSD - (2x) WD Red 2TB - EVGA G3 650w - Corsair 760T
Evoo Gaming 15"
i7-9750H - 16GB DDR4 - GTX 1660Ti - 480GB SSD M.2 - 1TB 2.5" BX500 SSD
VM + NAS Server (ProxMox 6.3)
1x Xeon E5-2690 v2  - 92GB ECC DDR3 - Quadro 4000 - Dell H310 HBA (Flashed with IT firmware) -500GB Crucial MX500 (Proxmox Host) Kingston 128GB SSD (FreeNAS dev/ID passthrough) - 8x4TB Toshiba N300 HDD
Toys: Ender 3 Pro, Oculus Rift CV1, Oculus Quest 2, about half a dozen raspberry Pis (2b to 4), Arduino Uno, Arduino Mega, Arduino nano (x3), Arduino nano pro, Atomic Pi.
https://linustechtips.com/topic/980755-help-me/#findComment-11833956
Are you plugging the monitor into the GPU or the motherboard?
Make sure to quote or tag me (@JoostinOnline) or I won't see your response!
PSU Tier List  |  The Real Reason Delidding Improves Temperatures"2K" does not mean 2560×1440
https://linustechtips.com/topic/980755-help-me/#findComment-11833987
6 minutes ago, Dragi said:
GPU and motherboard test and not working.
Bios update needed. Go to the AMD website and request a boot kit.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/980755-help-me/#findComment-11834029
9 hours ago, Dragi said:
Ryzen 7  2700X
Asus prime B350 plus
350 chipset needs a BIOS update to run 2nd gen Ryzen. The bad part is you have to find a processor that works with that socket in order to do the BIOS update. If I were you, I'd return the board and get a b450 like this.
Rest In Peace my old signature...                  September 11th 2018 ~ December 26th 2018
https://linustechtips.com/topic/980755-help-me/#findComment-11835761
Thank you
https://linustechtips.com/topic/980755-help-me/#findComment-11841082
