So as the title reads my pc has been suffering from low fps recently and I don't know why.
My specs are:
i5 8600k cooled by a kraken x62
gtx 1080
16gb ddr4 3000mhz
650w
I mostly play rainbow six siege and I used to have a stable 180-200 fps and now all of a sudden my fps has deterioted to 90-100 and I haven't changed any settings regarding clock speed or ratios on my cpu. What's even stranger is that my gpu is running at 100% and my cpu 60% under load. I highly doubt that there's a bottleneck either.
How could this be? If any more information is required I'll keep in touch.
thanks in advance
https://linustechtips.com/topic/980750-low-fps-unknown-reason/
13 minutes ago, davve146 said:
I built it this summer so not sure if it needs cleaning, however my 1tb hard drive that my games are on is almost full. could it be that? The temp is on average 55 on all cores
I don't think it's that. Check and see what's running at startup.
https://linustechtips.com/topic/980750-low-fps-unknown-reason/#findComment-11833955
It's definately not that. I only have 5 things activated on startup. What's strange is that when I'm multitasking (gaming and working) my fps stays the same.
That's interesting. I don't know what it is then. Sorry!
https://linustechtips.com/topic/980750-low-fps-unknown-reason/#findComment-11833984
it could be the HDD.  have you defragged it recently?  HDDS do need to have that done occasionally, its toxic for SSDs.  Windows normally schedules these things at times when you are not using your PC.  But if you shut it down regularly it may be unable.
Linux Daily Driver:
CPU: R5 2400G
Motherboard: MSI B350M Mortar
RAM: 32GB Corsair Vengeance LPX DDR4
HDD: 1TB POS HDD from an old Dell
SSD: 256GB WD Black NVMe M.2
Case: Phanteks Mini XL DS
PSU: 1200W Corsair HX1200
Gaming Rig:
CPU: i7 6700K @ 4.4GHz
Motherboard: Gigabyte Z270-N Wi-Fi ITX
RAM: 16GB Corsair Vengeance LPX DDR4
GPU: Asus Turbo GTX 1070 @ 2GHz
HDD: 3TB Toshiba something or other
SSD: 512GB WD Black NVMe M.2
Case: Shared with Daily - Phanteks Mini XL DS
PSU: Shared with Daily - 1200W Corsair HX1200
Server
CPU: Ryzen7 1700
Motherboard: MSI X370 SLI Plus
RAM: 8GB Corsair Vengeance LPX DDR4
GPU: Nvidia GT 710
HDD: 1X 10TB Seagate ironwolf NAS Drive.  4X 3TB WD Red NAS Drive.
SSD: Adata 128GB
Case: NZXT Source 210 (white)
PSU: EVGA 650 G2 80Plus Gold
https://linustechtips.com/topic/980750-low-fps-unknown-reason/#findComment-11833990
I just ran a quick check with windows defender and it gave no results. Does defragging mean going into the command prompt sfc/scannow? I do recall doing that recetly but I could try again. The only change my pc has gone through is the quick add-up of video files on my hdd. 'vs been recording my gameplay and stored it on my hdd. Am I correct about the defrag and should I run one?
Thanks for the quick replies!
https://linustechtips.com/topic/980750-low-fps-unknown-reason/#findComment-11834055
Thanks a lot! Does this take time? I'll try that before going to bed in that case and inform you tomorrow what the result is. Thanks a lot for the advice
Quote
You can defrag your hard drive by opening This PC right click on your hard drive click properties. Go to Tools and click optimize. Then a window will open in that window again click optimize.
https://linustechtips.com/topic/980750-low-fps-unknown-reason/#findComment-11834175
it cannot be a defrag issue. If it was a defrag issue, then loading would just take more. I think you have miner software installed on your computer. you should install kaspersky free anti virus.
CPU: 8600k @4.9  (1.39v) |  Cooler: NH-U14s | Mobo: Asus Strix z390i | Ram: Gskill DDR4 Trident Z 3600 8GB x 2 16-16-16-36
GPU: Gigabyte G1 1080 GTX | Case: Prodigy ITX | Fans: NH-A14, (exhaust) NH-A12, (intake) NH-A20 (intake)
Samsung EVO 1tb | Samsung EVO 512gb x2 | Intel ssd 128gb
PSU: Powerstation 500W
https://linustechtips.com/topic/980750-low-fps-unknown-reason/#findComment-11836059
I defragged my harddrive and it said "0% defragmented" or something. Unfortunately though I didn't have time to run any FPS tests today :(, but I'll keep my hopes up. I'll also check for mining software though I doubt there is any.
Sorry for late reply
https://linustechtips.com/topic/980750-low-fps-unknown-reason/#findComment-11838660
