Help, since Sunday my computer has not been able to boot. The system turns on, RGB on motherboard and fans turn on, BUT they turn off after a little while. I keep getting memory and Cpu error codes on my motherboard error display thing. IDK what to do. I have two hypotheses: One the PSU is not working, Two the motherboard is dead. If there needs to be more information just say so.
https://linustechtips.com/topic/979069-help-my-computer-will-not-boot/
Try and rule simple things out. Try powering on the system with a different known working PSU. Still doesn't work? Then you can cross that off the list. Is your RAM installed in the correct slots? The motherboard is the hardest to confirm as its quite laborious to replace the motherboard and test another and very few people have a spare board lying around and a friend isn't going to temporarily disassemble their system to loan you one.
Can you give us full system specs?
Gaming - Ryzen 9800X3D | 64GB 6400mhz cl30 9070 XT
Homelab - many servers...constantly changing.
3970X/256GB - 5950X/128GB ECC - 5600G/96GB - 3400GE/16GB - 3400GE/16GB
11 hours ago, lewdicrous said:
How did you come up with said hypothesis?
Remove everything except for the CPU (and its fan, of course) and try booting it
Ok, I will do that, But on how I got my hypothesis is by removing ram, removing CPU and putting it back into the computer and no function. I also tried multiple ram configurations.
Ryzen 1800x
Aorus Gaming 5 motherboard
16gb ram
1080
2 SSDs
1 HDD
750 Corsair PSU
I tried multiple ram configurations already and to no success, I reseated the CPU and still nothing.
1 hour ago, Mello said:
eh close enough...
Does your display show anything interesting? like an error code or some shit
Nothing at all it gets stuck in the boot I think
Error code 63 on the motherboard tho
But there is another one which I dont remeber
Wow it has codes? That's really useful
Now you need to grab as many codes as you can see.
in the manual (if don't have it, click here to download it) in page 40 you'll find debug codes and shit, 63 is "CPU DXE initialization is started."
Yea I read that on the manual but I didn't know what to do with it, I think the other error code was something to do with ram issues
10 hours ago, Mello said:
56 Invalid CPU type or speed. (wtf?)
93 PCI Bus hot plug initialization.
E9 S3 Resume PPI is not found. (I think it's talking about your front IO panel, I think you didn't connect it properly)
63~67 CPU DXE initialization is started.
Yea so I am a little confused on what to do. That's why I reseated the Cpu too.
  • 1 month later...
If the motherboard displays CPU errors and Motherboard errors, your CPU and Motherboard isnt dead.
With Great Power, Comes a Great Electricity Bill
Main
Setup: Intel core i5-8400 (OC'd), MSI Z-370-A Pro, Crucial Ballistix 8GB, Be Quiet! Pure Slim, Cooler Master Masterbox Lite 5 RGB, TP-Link Wifi Adapter, ASRock RX580, Artic Silver 3.5g Thermal Paste, Logitech G105, Logitech M310, Razer Sphex V2 (Mat), EVGA 500W 80+ Silver, 1TB WD Blue, 240gb Kingston Digital
