After what is now almost six years of using a laptop with GT 650M, I've decided to do an upgrade, a big one. I am planning to buy 2600X and pair it with GTX 1070Ti. My first intentions were to buy Turing once it comes out. However it just isn't what I was hoping for and those prices, I don't even want to talk about that. Yes, ray tracing does look good, but that is kinda useless when you cant afford it.:D. So I quickly reopted to Pascal and I think that 1070Ti is a card worth buying.
Since I want to do some 3D and videoediting besides gaming, AMD is better choice for me, especially now, when prices of Intel CPUs are so inflated
Quote
PCPartPicker part list: https://de.pcpartpicker.com/list/RzRCgw
CPU: AMD - Ryzen 5 2600X 3.6GHz 6-Core Processor  (€214.90 @ Caseking)
CPU Cooler: Cooler Master - MasterLiquid ML240L RGB 66.7 CFM Liquid CPU Cooler  (Purchased For €0.00)
Motherboard: Asus - ROG STRIX X470-F Gaming ATX AM4 Motherboard  (Purchased For €213.00)
Memory: G.Skill - Trident Z RGB 16GB (2 x 8GB) DDR4-3000 Memory  (€170.00)
Storage: Samsung - 860 Evo 250GB 2.5" Solid State Drive  (€58.00)
Storage: Toshiba - P300 2TB 3.5" 7200RPM Internal Hard Drive  (€59.90 @ Caseking)
Video Card: Asus - GeForce GTX 1070 Ti 8GB ROG STRIX Video Card  (€525.00)
Case: Fractal Design - Meshify C Dark TG ATX Mid Tower Case  (€90.89 @ Alternate)
Power Supply: Corsair - RMx (2018) 750W 80+ Gold Certified Fully-Modular ATX Power Supply  (€108.00)
Monitor: Dell - U2518D 25.0" 2560x1440 60Hz Monitor
Total: €1439.69
I've already bought the mobo, because I got a good deal on it - I got the AIO gratis with it.
There are also some other things I want to discuss. I am still not sure if I should buy the GPU now. 2070 benchmarks are just around the corner so I'll wait at least for that. However there are also rumours about yet another Polaris refresh, that could maybe lower the prices just a bit. Or maybe the prices will rise owing to US tariffs - I know that EU isn't directly affected by them, but what if manufacturers decide to increase prices here too by few percent to make the difference between EU and US smaller? I was also thinking about waiting till 7nm GPUs arrive. Like getting something really cheap now and upgrade next year. On the other hand I really don't want to wait any longer. Almost every day I see a game coming out which I'd like to play but my PC can't handle it.
So, that's basically it. What do you guys think?
https://linustechtips.com/topic/978892-new-ryzen-build-help/
A discrete gpu is required to make the system usable. So delaying the gpu purchase should mean delaying the entire purchase. Personally, if there is no pressing need I'd wait for independent RTX 2070 benchmarks and availability.
https://linustechtips.com/topic/978892-new-ryzen-build-help/#findComment-11819698
7 minutes ago, MaktimS said:
Anyone?
Build something like this instead....
It'll perform better and will have a better resale value...
2600 when overclocked performs similar to a 2600x. Currently 2600x is around €50 more than a 2600. Which doesn't justify then extra performance gained.
I have even managed to add a 1080ti..
CPU: AMD - Ryzen 5 2600 3.4GHz 6-Core Processor  (€165.89 @ Alternate)
Motherboard: ASRock - B450 Pro4 ATX AM4 Motherboard  (€95.46 @ Mindfactory)
Memory: Corsair - Vengeance LPX 16GB (2 x 8GB) DDR4-3000 Memory  (€134.90 @ Amazon Deutschland)
Storage: Crucial - BX500 480GB 2.5" Solid State Drive  (€76.12 @ Amazon Deutschland)
Storage: Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  (€58.55 @ Amazon Deutschland)
Video Card: Gigabyte - GeForce GTX 1080 Ti 11GB Gaming OC 11G  Video Card  (€754.99 @ Amazon Deutschland)
Case: NZXT - H500 (White) ATX Mid Tower Case  (€85.89 @ Alternate)
Power Supply: SeaSonic - FOCUS Plus Gold 650W 80+ Gold Certified Fully-Modular ATX Power Supply  (€85.99 @ Amazon Deutschland)
Total: €1457.79
Generated by PCPartPicker 2018-10-04 15:43 CEST+0200
https://linustechtips.com/topic/978892-new-ryzen-build-help/#findComment-11819704
2600 when overclock Ed performs similar to a 2600x. Currently 2600x is around €50 more than a 2600. Which doesn't justify then extra performance gained.
That looks great, however I've already bought the mobo so I'm not sure if I can fit a 1080Ti into my budget, but I'll definitely try :D
https://linustechtips.com/topic/978892-new-ryzen-build-help/#findComment-11819930
