Hi,
when I launched the games, I notice that are run very badly. I have this laptop G502VS-FY091T and I try to change the settings for energy saving, but nothing, than I try to reinstall the driver for the GPU, but nothing, I try also to change the settings in the NVIDIA contol panel and this also doesn't work. In the and I disabled the integrated GPU but it doesn't work either. How can I risolve this ?
Thanks for helping me.
https://linustechtips.com/topic/978331-low-fps-in-games/
How "badly" they run ?
Have you tried right click on the game and launching it with the performance GPU (Nvidia) ?
Are you in power saving mode ?
Have you tried pulling the battery out while gaming ?
What is your CPU and GPU Usage while gaming - it will be good to provide a graph or something with some game running.
https://linustechtips.com/topic/978331-low-fps-in-games/#findComment-11811361
Sorry for my english, but I'm italian and I don't speek english everyday.
first question: 40 fps
secondo question: i tried right click but there is not to lunching the game withe the GPU. I disabled the GPU processor
third question: no i'm not
fourth question: the battery can not remove
https://linustechtips.com/topic/978331-low-fps-in-games/#findComment-11811606
Your benchmark scores are perfectly okay for those specs in a laptop in an extreme benchmark. I dont understand what the problem is. what settings do you use in games. because you cant expect to have 100+ fps on ultra in a recent tripple A game with that setup.
Also when you disconnect the power plug your laptop could automaticly switch to power saving mode causing your hardware to clock down and results in lower fps in games. Try changing the windows setting so you are always in performance mode.
TL;DR
Your performance seems fine, check power saving mode.
https://linustechtips.com/topic/978331-low-fps-in-games/#findComment-11811689
From what I can see there is no problem with the score, but know that benchmarking is different than real life gaming, it would be best to run a game for 5 min and then show us your CPU and GPU usage, so we can see where's the spiking. Specific games has specific issues, would be best to also tell us in which graphic settings you play the game of your choice.
https://linustechtips.com/topic/978331-low-fps-in-games/#findComment-11811705
9 hours ago, Condor454 said:
Hi,
What games have you actually tested that give you low FPS? I only see Unigine with low FPS. It's not exactly a game. :D
CPU: Sempron 2500+ / P4 2.8E / P4 2.6C / A64 x2 4000+ / E6420 / E8500 / i5-3470 / i7-3770
GPU: TNT2 M64 / Radeon 9000 / MX 440-SE / 7300GT / Radeon 4670 / GTS 250 / Radeon 7950 / 660 Ti
https://linustechtips.com/topic/978331-low-fps-in-games/#findComment-11812634
I tested with Rainbow Six. When I go on the settings, it actually gives me that I'm using the 1070, to make it runnig smooth I must use 3gb of 8 gb
https://linustechtips.com/topic/978331-low-fps-in-games/#findComment-11812906
TL;DR
I'm sure I'm not on power saving mode... i check this serveral times
https://linustechtips.com/topic/978331-low-fps-in-games/#findComment-11812956
I play R6 for 15 minuties and this is the result
https://linustechtips.com/topic/978331-low-fps-in-games/#findComment-11812973
