How much of a difference is there between the :
MSI GTX 1070 Ti titanium 8gb
MSI GTX 1080 Gaming - X 8gb
 In frames and maxed out 1080p
And 1440p if I get a better monitor later
Best Value Build List
Budget 1080p System (RGB) https://pcpartpicker.com/list/7v2Lmq - (this build comes with two free games with the RX 570)
https://linustechtips.com/topic/978012-how-much-of-a-difference/
As you can see in CPU heavy games, the difference won't be that noticiable if any at all.
here you can see in other games
From what I can see the difference is small, the 1080 has the upper, but if you can find 1070ti real cheap it's the better bang for the buck choice.
In 1440p the better choice would be 1080
In 1080p there most likely won't be a difference. In 1440p there will be more of a noticable difference, but if you only have a 60Hz monitor then it won't matter which one you get.
My Build, v2.1 --- CPU: i7-8700K @ 5.2GHz/1.288v || MoBo: Asus ROG STRIX Z390-E Gaming || RAM: 4x4GB G.SKILL Ripjaws 4 2666 14-14-14-33 || Cooler: Custom Loop || GPU: EVGA GTX 1080 Ti SC Black, on water || PSU: EVGA G2 850W || Case: Corsair 450D || SSD: 850 Evo 250GB, Intel 660p 2TB || Storage: WD Blue 2TB || G502 & Glorious PCGR Fully Custom 80% Keyboard || MX34VQ, PG278Q, PB278Q
Audio --- Headphones: Massdrop x Sennheiser HD 6XX || Amp: Schiit Audio Magni 3 || DAC: Schiit Audio Modi 3 || Mic: Blue Yeti
[Under Construction]
My Truck --- 2002 F-350 7.3 Powerstroke || 6-speed
My Car --- 2006 Mustang GT || 5-speed || BBK LTs, O/R X, MBRP Cat-back || BBK Lowering Springs, LCAs || 2007 GT500 wheels w/ 245s/285s
The Experiment --- CPU: i5-3570K @ 4.0 GHz || MoBo: Asus P8Z77-V LK || RAM: 16GB Corsair 1600 4x4 || Cooler: CM Hyper 212 Evo || GPUs: Asus GTX 750 Ti, || PSU: Corsair TX750M Gold || Case: Thermaltake Core G21 TG || SSD: 840 Pro 128GB || HDD: Seagate Barracuda 2TB
R.I.P. Asus X99-A motherboard, April 2016 - October 2018, may you rest in peace. 5820K, if I ever buy you a new board, it'll be a good one.
High end GPU with 60hz monitor, I don't want to live in the world you describe
Would either of you be pay an extra $80 for the 1080 compared to the 1070Ti
Or should I just go for the 1070Ti
Depends on your income. Do you have one ?
Personally I would do, I already did actually and the difference wasn't 80$, but that's because I have a salary and 80$ doesn't sound so bad if you have money every month.
If you're on a tight budget on the other hand, then take the 1070ti, and invenst those 80$ into a better monitor or SSD if you don't have one already
Personally I would do, I already did actually and the difference wasn't 80$.
I work with my uncle's hardware shop and do pc builds on the side
My pays $65 a week and I make $50 Fer system I put together
That's wonderful, then picture it like this. If you can wait 1 week and build a single system, then "if we take that you have saved the money already" you'll be able to afford the 1080 with you will be much happier - because you'll have made 115$, and you'll be left with 35 extra. If you haven't saved the money yet, then depends on how much time you can wait until you can buy the GPU if you can't wait, buy the GTX 1070ti
I see OK thanks
I’d do 1080. Not much for mid tier stuff myself. Though it would fall well into that category now. Plenty around used to not waste getting either for that price.
If it’s something you plan on keeping while, why not get the strongest card you can now.
