Question about safe temps
Those kind of temperatures are not abnormal for laptops. While it's impossible to say if it's causing long term damage, for the short term it will be fine. It's certainly not going to die in a year or anything that drastic.
You hear all this talk about max safe temperature and it's all nonsense, Intel issues no such number. They do issue a T-junction number which is the maximum temperature allowed at the die before the processor will throttle and in most cases that number is around 100°c. There's an argument to be made that this means Intel 'rate' their CPUs upto 100°c however any electrical engineer will tell you that running electronics that hot will cause damage over long periods.
It's upto you to decide the balance between heat & longevity however in a laptop it's not easy to reduce temperature. Honestly 85°c isn't the end of the world, in a PC I'd be saying do something about it but in a laptop it is what it is.
