you can cf with any other 270x
AMD Athlon X4 750k; Gigabyte F2A88XM-DS2; 8Gb Corsair XMS 1600 Mhz; AMD Hd5670 1Gb DDR3; Bequiet E6-600W; W7 Ultimate x64
#KILLEDMYWIFE        so miner; very doge; much value
Dell Vostro 5470: i5 4200U Nvidia GT740m 2Gb 14" 1366x768 Kingston V300 120Gb
https://linustechtips.com/topic/97770-need-help/#findComment-1307785
It will, the settings will use the lower cards settings
Main Rig CPU: AMD Ryzen 7 5700x GPU: Asus TUF Gaming RTX 3080 OC MBASUS AM4 TUF Gaming X570-Plus RAM: 64GB Corsair Dominator Platinum 3200 CPU Cooler: Cooler Master Master Liquid LC240E SSD: Crucial 250gb M.2 + Crucial 500gb SSD + 4TB Crucial SSD HDD:None PSU: Thermaltake Toughpower Gran RGB 850W 80+ Gold Case: Corsair Carbide 275R KB: Glorious GMMK 85% MOUSE: Razer Naga Trinity HEADSET: Go XLR with Shure SM7B mic and beyerdynamic DT 990
unRAID Plex Server CPU: Intel i7 6700 GPU: Nvidia Quadro P2000 MB: Asus B150M-C RAM: Crucial Ballistix 32gb DDR4 3000MT/s CPU Cooler: Stock Intel SSD: Western Digital 500GB Red HDD: 4TB Seagate Baracude 3x 4TB Seagate Ironwolf PSU: EVGA BT 80+ Bronze 450W Case: Cooler Master HAF XB EVO KB: Cheap Logitech KB + Mouse combo
https://linustechtips.com/topic/97770-need-help/#findComment-1307815
One last question, if i overclock this card to match speed of my current card i won't lose performance, but since this one has 4gb vram compared to my card which has 2gb. are they still able to be CF?
AMD diehard & Nvidia Enthusiest
https://linustechtips.com/topic/97770-need-help/#findComment-1307828
I would get a card with the same vram, otherwise your crossfire will only be using 2GB of vram. It's best to keep both cards the same specs, otherwise you get the performance and specs of the card that is lowest.
https://linustechtips.com/topic/97770-need-help/#findComment-1308899
What would be the max temp u would want to keep under at an overclock of 4.2ghz
My max temp is around 39c.
Life is pain. Anyone who says any different is either selling something or the government.
----CPU: FX-6300 @ 4.2ghz----COOLER: Hyper 212 EVO----MOBO: MSI 970A-G46----PSU: OCZ 600watt----CASE: Black Corsair C70----GPU: Sapphire 7870 dual fan ghz edtion----2 random HDD'S----A couple fans here and there. Mouse: Gigabyte M6900-------Keyboard: Logitech G105-----Mousepad: Steel series something something.
https://linustechtips.com/topic/97770-need-help/#findComment-1309379
Would be a bad thing to pair up a i5 4670 with a gtx 780 if yes what would be the best match in the nvidia geforce line
And maybe wat would be the best combination for the gtx 780
A 780 works fine.
Get what you need. There's never only one way to do things.
80-90c.
Idle temps are pretty irrelevant.
https://linustechtips.com/topic/97770-need-help/#findComment-1311111
A 780 works fine.
80-90c.
That is my max temp. Not idle temp.
https://linustechtips.com/topic/97770-need-help/#findComment-1313141
I thought you were referring to the 4670k because that's what the @Achillo2130 was talking about.
https://linustechtips.com/topic/97770-need-help/#findComment-1315240
Oops sorry. I must have had a brain relapse. My bad.
https://linustechtips.com/topic/97770-need-help/#findComment-1315395
