NF-F12 PPC 3000 PWM in H500P
JHurley7nrx
Not sure why you need 3000RPM, they are deafening if you make them go that fast.
Desktop benching:
why do you go with 3x120mm when you can fit 3x140? 3 low rpm-140's are able to move the same air with less noise (if proper fans chosen), or can move more air at the same noise. so yes; 3x120mm PPC 3000's is possible, though I don't think it is the best option
