Need a quick help
By
Chillerzz
in Power Supplies
in Power Supplies
Solved by Jurrunio,
Yes that's true. Not so much about the rated power output, but the quality of its internals.
https://linustechtips.com/main/topic/631048-psu-tier-list-updated
Get something tier 3 or higher. 450w is enough, but 550w will let you use bigger upgrades to the GPU and CPU. No need to go higher than 650w for a single GPU setup, unless its Vega.
YoungBlade ·
Posted in CPUs, Motherboards, and Memory5 -
derekchan ·
Posted in New Builds and Planning6 -
5
4
6
kerriya ·
Posted in Cases and Mods9 -
octester ·
Posted in Troubleshooting8
play_circle_filled
Latest From ShortCircuit:
