You may need a BIOS update to support 3rd Gen CPUs.
You can use pretty much any DDR3 non-ECC memory with that motherboard and CPU.
https://linustechtips.com/topic/977468-need-mb-cpu-help/#findComment-11803590
1 minute ago, ikksss said:
can u help me , which bios i need ? cause im gonna buy that cpu tomorrow
im not bad in pc but if u help ill be glad never did this before and will be little lesson for me
get into the BIOS and find its version first
Desktop benching:
https://linustechtips.com/topic/977468-need-mb-cpu-help/#findComment-11803605
