I bought a asus rog GL753VE
spec:
I7 7700HQ
GTX 1050ti
8GB ram
128gb SSD
1TB HDD
before when i start csgo i consistently get 150-170 fps and my cpu usage is at 60-70% and my gpu is at 30%
but now i only get 90 and below fps  my cpu usage is only at 30-40% and my gpu is at 20% I even tried to do the things they said on the internet like remove the fps cap
lower all the settings lower the resolution and non of it worked any solutions?
https://linustechtips.com/topic/976996-csgo-low-fps/
are you sure it's running on the nvidia card and not the integrated graphics?
Edited by firelighter487
typo
She/Her
Phone: OnePlus Nord CE 5G | 128GB | 8GB Ram
Main Desktop: Ryzen 5 3600 | GTX 1060 6GB | 32GB Ram
Main Laptop: Acer Aspire V3-771G | Core i7 3612QM | 16GB
https://linustechtips.com/topic/976996-csgo-low-fps/#findComment-11799500
3 minutes ago, GKM said:
yes its running on my GTX 1050ti
quote me or i won't get a notification.
how are you monitoring gpu usage?
is vsync off?
She/Her
https://linustechtips.com/topic/976996-csgo-low-fps/#findComment-11799520
use this button
also have you checked thermals? how old is your laptop and have you dusted it out?
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/976996-csgo-low-fps/#findComment-11799566
1 minute ago, fasauceome said:
use this button
I only bought this last December and in terms of dust dont think it would affect my laptop this early. my cpu is at 82-85C and my gpu is at 60-70 degrees
https://linustechtips.com/topic/976996-csgo-low-fps/#findComment-11799581
Have any other games been affected
Primary PC:
PSU tier list
https://linustechtips.com/topic/976996-csgo-low-fps/#findComment-11799610
Just now, GKM said:
other games isnt affected
So hopefully it's only a problem in Csgo and not a hardware issue. Tried any special graphics configs in the console?
Primary PC:
PSU tier list
https://linustechtips.com/topic/976996-csgo-low-fps/#findComment-11799793
yeah i tried some and at the first 20mins of the game my fps was improved but after that it will become 70 fps again
https://linustechtips.com/topic/976996-csgo-low-fps/#findComment-11799806
