I have i7-4770 CPU paired with ASUS H81T mobo.
I have installed custom cpu fan Antec A30. no error.
Recently i have replaced the Antec A30 fan with normal Intel stock fan.
Every time system boots, it is giving me error "CPU Fan error! press F1 to Continue"
what could be the problem? how can i solve this?
PS: System is working normal
Only the error comes up with every boot.
WhatsApp Video 2018-09-28 at 3.59.33 PM.mp4
Edited by PRATAP KUMAR PANABAKA
Pics added.
https://linustechtips.com/topic/976948-cpu-fan-error/
Is the cpu cooler fan spinning? Do you have a fan plugged into the cpu_fan header?
The error pops up when there isn't a fan rpm detected from the cpu_fan header or the rpm is too low. The setting can usually be turned off in the motherboard settings.
https://linustechtips.com/topic/976948-cpu-fan-error/#findComment-11799086
it could be 1 pin off to the side and still "feel" connected.
Unless it has a alignment thingy, then i said nothing
Positive Mental Additude!
Just another Tired IT guy...
https://linustechtips.com/topic/976948-cpu-fan-error/#findComment-11799088
fan is running.. PC works as normal except that error in every boot after changing the custom fan to stock fan.
https://linustechtips.com/topic/976948-cpu-fan-error/#findComment-11799106
https://linustechtips.com/topic/976948-cpu-fan-error/#findComment-11799123
11 hours ago, PRATAP KUMAR PANABAKA said:
yes, fan is plugged into the cpu_fan header.
What rpm is the fan running at?
https://linustechtips.com/topic/976948-cpu-fan-error/#findComment-11800955
