If it's the latest bios or says "added 2nd gen ryzen support" in the release notes, chances are it supports 2nd gen ryzen.
Ryzen 5 1600 @ 3.9 Ghz  | Gigabyte AB350M Gaming 3 |  PaliT GTX 1050Ti  |  8gb Kingston HyperX Fury @ 2933 Mhz  |  Corsair CX550m  |  1 TB WD Blue HDD
Inside some old case I found lying around.
https://linustechtips.com/topic/976943-bios-problem/#findComment-11799046
1 minute ago, Almighty_Joe- said:
It only says this
Description
- Update AGESA Code 1.0.0.4C
- Improve memory compatibility.
Is it the latest update? If it is, yes it supports ryzen+
https://linustechtips.com/topic/976943-bios-problem/#findComment-11799055
9 minutes ago, peacefulpolarbear said:
Update your bios and it will definitely work. Any version that is from March or later will work. I just checked MSI’s site. Use the latest one though. Good luck.
Edit: also, every bios update contains all other past updates, you don’t need to install anything sequentially.
Cause I remember my friend cant boot his ryzen 5 2400G even after updating with the latest bios. He has a X370 SLI plus
https://linustechtips.com/topic/976943-bios-problem/#findComment-11799094
