is it okie to have the voltage set at auto, it hits max voltage to 1.332V when playing games.
im overclocking i5 6600k to 4.5ghz.
it idles at 0.864V - 1.000v and jumps to 1.3v if needed or should i keep it consistent 1.335v?
is that consider safe if the voltage jumps up and down in the safe range.
https://linustechtips.com/topic/976846-cpu-voltage-help-auto/
Voltage changing is safe, as long as it doesn't exceed the max you've set, since much higher would be no good. Less voltage when idle is better because it's using less power when not needed.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/976846-cpu-voltage-help-auto/#findComment-11798033
thank you I just figure it out how to use dynamic v core on gigabyte z170 hd3
https://linustechtips.com/topic/976846-cpu-voltage-help-auto/#findComment-11798036
but I have to switch my voltage setting back to auto.
Might as well manually change the voltage, auto is pretty generous so toying with voltage to get it as low as possible is ideal.
Primary PC:
PSU tier list
https://linustechtips.com/topic/976846-cpu-voltage-help-auto/#findComment-11798038
well you see idk why dvid is grey out when i  try to put manual voltage. I'm still new to this
do I put the max voltage and use minus - (set a voltage to the lowest when idle)?
https://linustechtips.com/topic/976846-cpu-voltage-help-auto/#findComment-11798042
Unfortunately I haven't done enough overclocking on gigabyte motherboards to know that for sure, so I think you should check out some YouTube tutorials to really nail it down
Primary PC:
PSU tier list
https://linustechtips.com/topic/976846-cpu-voltage-help-auto/#findComment-11798050
39 minutes ago, Chriszzz said:
well i found out that I need 1.382v for a stable 4.6ghz
1.332v for 4,5ghz
idle voltage 0.864 - 1.1v on lowest core 800mhz
I don't recommend 1.38 for regular use in the long term, so maybe stick to 4.5
Primary PC:
PSU tier list
https://linustechtips.com/topic/976846-cpu-voltage-help-auto/#findComment-11798418
my max temps are 55-60c gaming 4.6ghz usually hit 1.38-1.39.
idle are around 20c voltage drops
is it still bad?
though 4.6ghz the voltage does spike up it doesn't go beyond the voltage of 1.4v
hwmonitor shows sometimes i go idle 0.840v jumps straight to 0.135v - 0.139v
https://linustechtips.com/topic/976846-cpu-voltage-help-auto/#findComment-11798489
alright nvm i don't know how to get DVID to work on gigabyte z170, it works on auto and normal, but doesn't give consistant v core, when auto even with LLC on high. maybe i add more DVID +.
trying to look everywhere but only have voltage settings AUTO, Normal. manual
i can add DVID if the setting is normal but the setting is on auto voltage and its still not stable, when I play games.
https://linustechtips.com/topic/976846-cpu-voltage-help-auto/#findComment-11798519
