Update your CPU.
EDIT: Wait, nvm, it's a laptop.
CPU: AMD Ryzen 5 5600X | MOBO: MSI B450 Tomahawk GPU: AMD Radeon RX 6800XT | RAM: GSkill Trident Z DDR4 3600Mhz | PSU: ADATA Core Reactor 850W 80+ Gold | CASE: Fractal Design Meshify C MONITOR: LG 32UL500-W 4K 60Hz, Gigabyte M27Q 1440p 165Hz
Your CPU is super old. Grab a ryzen processor if it's in budget (or find a sweet deal for a used core i5 or something)
With a modern CPU comes a new motherboard and ram. Use pcpartpicker.com to make a parts list so you can share it and ask what we think.
Primary PC:
PSU tier list
How many watts do I need?
Side note: upgrading to an SSD with windows 10 is a good idea, I agree with the website.
Primary PC:
PSU tier list
Already have a Corsair H60 Water Cooler (i Plan to OC) and a 500W EVGA PSU. I also have an adapter for a laptop SSD to desktop (I have a Kingston 256GB SSD M.2).
https://pcpartpicker.com/list/RRDQfH
however, idk how to deal with the compatability issue
So a few notes:
You can't overclock with an a320 motherboard
Your incompatibility is due to the fact that most first gen ryzen boards (a320, b350, x370) needed an update to run second gen ryzen CPUs. If yours arrives needing a BIOS update, AMD will ship you a free boot kit to fix this. You can ask on the forums for help from there (but I personally feel like Google can help more)
You don't need a "laptop to desktop" converter for an SSD if you get a motherboard  with an m.2 slot on it, I though it'll be standard with most b350 and up boards, which is what you should get.
Primary PC:
PSU tier list
3 minutes ago, Death Wish said:
hmm ill look into that, im planning on buying an i3 8100, any motherboard recommendations?
https://pcpartpicker.com/list/pqRQ6s
Try this.
The i3 setup will be a bit more:
https://pcpartpicker.com/list/DHnsKB
Picking the absolute bottom of the barrel parts was a little worse than 2 options up, so I selected that
Both motherboards have an m.2 slot so the SSD you have can be inserted directly into the motherboard, above the slot for the graphics card
Primary PC:
PSU tier list
What's your budget for the whole upgrade?
Ryzen 5 1600 @ 3.9 Ghz  | Gigabyte AB350M Gaming 3 |  PaliT GTX 1050Ti  |  8gb Kingston HyperX Fury @ 2933 Mhz  |  Corsair CX550m  |  1 TB WD Blue HDD
Inside some old case I found lying around.
Just now, Death Wish said:
below $250
Oof, doesn't look like room for the i3 build then, but IMO if you save up, it's worth it because you can upgrade to an i5 8400 or something in the future later
Primary PC:
PSU tier list
20 minutes ago, Death Wish said:
below $250
Assuming you only need CPU/Mobo/RAM:
PCPartPicker part list: https://pcpartpicker.com/list/8chWKB
Price breakdown by merchant: https://pcpartpicker.com/list/8chWKB/by_merchant/
CPU: AMD - Ryzen 3 1200 3.1GHz Quad-Core Processor  ($93.89 @ OutletPC)
Motherboard: ASRock - B450M PRO4 Micro ATX AM4 Motherboard  ($79.99 @ Newegg)
Memory: Kingston - HyperX Fury 8GB (1 x 8GB) DDR4-2666 Memory  ($81.89 @ OutletPC)
Total: $255.77
A very good idea. As soon as I see the WIndows logo it takes 6 seconds for desktop to show up.  :)  But then it has to load the startup stuff sighs,,
Asus Sabertooth x79 / 4930k @ 4500 @ 1.408v / Gigabyte WF 2080 RTX / Corsair VG 64GB @ 1866 & AX1600i & H115i Pro @ 2x Noctua NF-A14 / Carbide 330r Blackout
Scarlett 2i2 Audio Interface / KRK Rokits 10" / Sennheiser HD 650 / Logitech G Pro Wireless Mouse & G915 Linear & G935 & C920 / SL 88 Grand / Cakewalk / NF-A14 Int P12 Ex
AOC 40" 4k Curved / LG 55" OLED C9 120hz / LaCie Porsche Design 2TB & 500GB / Samsung 950 Pro 500GB / 850 Pro 500GB / Crucial m4 500GB / Asus M.2 Card
