Are these Specs Good for running most games on ultra/high?        Display Type: QFHD 3840 x 2160 17.3" IPS G-SYNC Matte
Display Processors: Intel Core i7 8700K 6-Core 3.7GHz (4.7GHz TurboBoost)
Graphic Cards: NVIDIA GeForce GTX 1080 8GB [VR Ready]
Thermal Compound: GELID GC-Extreme Graphics Card Application
Memory: 32GB Kingston HyperX Impact 3200MHz (2 X 16GB)
Operating System: MS Windows 10
Home M.2 SSD Option: m.2 SSD OS Drive
M.2 RAID Configuration: RAID 0: For better speed and performance
M.2 SSD Drive: 1TB Samsung 970 EVO PCIe NVMe M.2 M.2 SSD
Drive Two: 250GB Samsung 970 EVO PCIe NVMe M.2 Hard Drive RAID Configuration: RAID 1: For better data safety and security
LT Hard Drive: 1TB Samsung 860 EVO Series Hard Drive
https://linustechtips.com/topic/976420-pc-spec-help/
Not at 4k, no.  At 1080p, sure.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose. Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/976420-pc-spec-help/#findComment-11794373
No. You will need 1080 SLI or 2080ti to do that at 4k, targeting 60fps.
Desktop benching:
https://linustechtips.com/topic/976420-pc-spec-help/#findComment-11794385
Get a 2080Ti if you want Ultra/High and 4K.  1080Ti/2080 for High/Med 4k,
You don't need the 32GB RAM, get 16 and spend the rest on a better GPU.
OnePlus Ecosystem:
3D Printing:
https://linustechtips.com/topic/976420-pc-spec-help/#findComment-11794389
1 minute ago, [TCE] Nomad said:
It is yeah.
If you don't need the portability of a laptop, getting a desktop with some rebalanced specs would do nicely, but for a laptop this is pretty great.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/976420-pc-spec-help/#findComment-11794414
4 minutes ago, [TCE] Nomad said:
It is yeah.
Do you mind if I ask which country are you from and what's your budget? That laptop is specced out and honestly is more powerful than my ITX desktop but you might want to consider other brands that would give you a 144Hz screen at 1440p ect.
4K is great but you will still struggle to hit 4k 60fps on a mobile 1080 and at 17 inches it's honestly hard to tell the difference between 1440p and 4k
https://linustechtips.com/topic/976420-pc-spec-help/#findComment-11794416
4K is great but you will still struggle to hit 4k 60fps on a mobile 1080 and at 17 inches 4k really isn't required.
I'm in the United States, budget is around 5000.
https://linustechtips.com/topic/976420-pc-spec-help/#findComment-11794420
I'm not sure if this laptop can fit (as in have) a 1080ti, but from what I understand, it can't run 4k at high?
Not with that 1080, most likely throttled for temps as well.  Sorry.
It may run SOME games at High 4k, but as a general rule you'll have to lower and tweak some settings.
Edit:  You won't notice 1080p vs 4k on that 17 inch screen anyway, so just run games on High/Ultra in 1080p.
OnePlus Ecosystem:
3D Printing:
https://linustechtips.com/topic/976420-pc-spec-help/#findComment-11794428
Could you recommend what settings to change? I'm not good with this stuff ^^
https://linustechtips.com/topic/976420-pc-spec-help/#findComment-11794434
It's gonna vary game to game, there's settings like antialiasing, texture quality, shadow quality, etc you should experiment with to find out your ideal gaming experience.
Primary PC:
PSU tier list
https://linustechtips.com/topic/976420-pc-spec-help/#findComment-11794438
Damn, alright honestly that kind of budget is more than I know what to do with. I've posted a link on Newegg below with machines that are 17 inches have at least a 1080 and screens with 120 or 144Hz refresh rate. I'd say just take a look and see what you like.
https://www.newegg.com/Product/ProductList.aspx?Submit=ENE&IsNodeId=1&N=100167732 600553910 600553911 4814 601206466 601206491 601322144 601322145&cm_sp=CAT_Gaming-Laptops_1-_-VisNav-_-17.3-Inches-and-Up
https://linustechtips.com/topic/976420-pc-spec-help/#findComment-11794441
