Hey, guys.
I have this wierd issue since yesterday. My monitor started to show some red random pixels. An hour later it started to flicker sometimes. At first I thought it was the HDMI cable, but then I realized this only happened on certain tasks like games or YouTube.
Today I updated the Nvidia drivers and it went worst. It always flickers unless I am on the Google web page.
When I get home, I'll disassemble my PC, clean it and pray to every single God I know.
If you know anything, please comment it. Thanks ♥️
OS: Windows 10
CPU: Intel i3 2nd gen
GPU: Nvidia GTX 970 (Drivers updated)
RAM: 12 GB DDR3
No viruses detected
OS Windows 11
CPU AMD Ryzen 7 3700X (AM4)
MOBO ASUS ROG STRIX B450-F GAMING II
RAM Patriot V4s Viper Steel RGB DDR4 8 GB x4 (32 GB) 3200 MHz)
GPU NVIDIA GeForce GTX 1660 6 GB GDDR5
SDD Samsung 960 EVO 250 GB (MVME) // Adata Su650 480 GB (SATA)
HDD Western Digital WD20EZRZ 2 TB 5400 RPM // TOSHIBA DT01ACA050 500 GB 7200 RPM
PSU NZXT Hale 82 V2 550 W 80+ Bronze
https://linustechtips.com/topic/976411-pc-flickering-and-red-dots/
When you expect it that it might be your gpu drivers:
-Start by using a program named DDU. (https://www.guru3d.com/files-details/display-driver-uninstaller-download.html)
-Download and install new drivers from nvidia.
Just uninstalling them through admin panel isn't complete enough to be sure :)
It's a good point to start your troubleshooting journey.
Edited by partymarty
added DDU link
PC Specs: Intel Core i7-8700k - Asus ROG Z370 MAXIMUS X HERO - 2x8gb Kingston Predator DDR4 3200MHz - MSI GeForce GTX 1080 Ti gaming X Be Quiet! Dark Rock Pro 4 - Samsung 850 PRO 256gb - Samsung 850 EVO 500gb - Seagate Barracuda 2tb - Fractal Design Meshify C - Asus PCE-AC56 - Be Quiet! Straight Power 10 CM 700W.
Peripherals: Corsair K70 LUX - Steelseries Rival 310 - Dell S2417DG - Beyerdynamic Custom One Pro - Audioengine D1.
Useless to get DDU. In the Nvidia drivers, you can pick "Advanced", and from there you can pick to do clean install. It will remove all traces from the previous drivers, ask you to restart, and once you restart (and you are logged back in) setup will resume soon after and install the drivers.
You can try and clean it, and make sure that the PCI-E lane is clean, but that is rare that is the case, but I guess, you never know and doesn't hurt.
But to me, it sounds like faulty GPU memory (from experience).
You'll need to pass your graphics card under warranty for replacement (or return to the store if it is still under the return window)
Do you mean from the Nvidia Experience or the other one?
OS Windows 11
