Hello,
as until today I was just reading in the Forum and today i build myself my new Desktop:
- AsRock Taichi x470
- Ryzen 2700X with dark rock Pro 4
- one 16 gb stick Gskill Ripjaws Ram
- MSI GTX 1080ti
- Straight power 11 750W PSU
- Samsung 860 evo M.2 SSD 1TB
Everything went smoothly, but some time ago the system started to micro-freeze/stutter when put under load.
for half a second the system freezes and the sound buzzes then everything goes on as normal for some seconds, then it happens again.
I tried to figure out whether the CPU or GPU temps are too high or if something else is wrong. sadly without success.
In ''normal'' conditions the system is fine, when I start a game it starts stuttering.
has anyone any ideas for me ?
Best regards.
Noroi
https://linustechtips.com/topic/976354-problems-with-new-build/
Funny thing, I've had that exact problem with a completely different build. Do you use overclocking software? My problem was tied to fan speed somehow, you should see how changing GPU fan speed affects the stuttering.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/976354-problems-with-new-build/#findComment-11793764
