For 1440p anything from 5-6th Gen Intel should be fine. Your most likely going to be GPU bottlenecked anyways with a 1080 so even a ryzen 1800 is probably good enough for most situations.
https://linustechtips.com/topic/976054-cpu-for-1080/#findComment-11790557
6 minutes ago, jordengx said:
now i have core i5 7500 3.4 ghz and boost to 3.6
do i need a new one?
You'll be better off with an Intel upgrade, but a 7700k would probably fare similar to an 8700k. Not exactly an enormous leap in performance in one generation.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/976054-cpu-for-1080/#findComment-11790595
That will be a bottleneck, but a fairly minor one. If you wanted to upgrade, get a 7600K.
Main PC:
AMD Ryzen 7 5800X • Noctua NH-D15 • MSI MAG B550 Tomahawk • 2x8GB G.skill Trident Z Neo 3600MHz CL16 • MSI VENTUS 3X GeForce RTX 3070 OC • Samsung 970 Evo 1TB • Samsung 860 Evo 1TB • Cosair iCUE 465X RGB • Corsair RMx 750W (White)
Peripherals/Other:
ASUS VG27AQ • G PRO K/DA • G502 Hero K/DA • G733 K/DA • G840 K/DA • Oculus Quest 2 • Nintendo Switch (Rev. 2)
Laptop (Dell XPS 13):
Intel Core i7-1195G7 • Intel Iris Xe Graphics • 16GB LPDDR4x 4267MHz • 512GB M.2 PCIe NVMe SSD • 13.4" OLED 3.5K InfinityEdge Display (3456x2160, 400nit, touch).
Got any questions about my system or peripherals? Feel free to tag me (@bellabichon) and I'll be happy to give you my two cents.
PSA: Posting a PCPartPicker list with no explanation isn't helpful for first-time builders :)
https://linustechtips.com/topic/976054-cpu-for-1080/#findComment-11790599
Since OP was considering an 8700k, I think the hassle free maxing out of the currently owned platform would be ideal
Primary PC:
PSU tier list
https://linustechtips.com/topic/976054-cpu-for-1080/#findComment-11790604
Sure, if they have the cash to do so. We don't know if OP's motherboard is an overclockable chipset, so recommendations aren't super useful at the moment. If OP has the cash for a 7700K, by all means, go for it. If not, the 7600K is a good option to prevent bottlenecking.
Main PC:
Peripherals/Other:
https://linustechtips.com/topic/976054-cpu-for-1080/#findComment-11790621
2 minutes ago, jordengx said:
i have a the lowest chipset h110, so the motherboard will effect on the Performence?
and what is the deferent between 7700K and 7600K (and do i even need the "K")?
So the 7700k is an i7, so it has 4 cores 8 threads (kind if acts like it has 8 cores). The 7600k is a four core four Thread. the K at the end will actually give you higher frequencies even without overclocking, so a 7700 K is better than a 7700 even on an h110 board. The 7600k does not have this advantage.
Log story short, the 7700k will be the best chip for your motherboard no matter what, in terms of performance.
Primary PC:
PSU tier list
https://linustechtips.com/topic/976054-cpu-for-1080/#findComment-11790656
Just now, jordengx said:
how much the jump from 7700 to 7700k would effect performance, will it be 10 more fps on average?
no way to know exact fps since it varies greatly game to game, but if budget is what you're after, a 7700 will cut it
Primary PC:
PSU tier list
https://linustechtips.com/topic/976054-cpu-for-1080/#findComment-11790698
14 minutes ago, jordengx said:
look, i found a deal and the deference between the two is 50$, and if i take the 7700k, what cooler i should choose (how much TDP)?
A cooler like the cryorig h7 is great
Primary PC:
PSU tier list
https://linustechtips.com/topic/976054-cpu-for-1080/#findComment-11790779
