im not going to be able to help ya. but just before other people jump on and help, u need to clarify some stuff and give some more details.
what do u plan to do with the PC?
How many monitors do you plan on running? Do you plan on moving to more monitors in the future? What resolution are they at too?
Do you also need to purchase peripherals such as keyboards and mice as well as monitors ect. Also if you'll need an OS such as Windows.
whether you need things like wireless card or sound card e.t.c.
Any preferred components?
Any spare parts you can re-use?
are you going to do some overclocking?
and anything else that hasnt been asked by these questions.
Just a guy with a beard
If you are building your first PC and have never had a decent one before, this would work http://pcpartpicker.com/user/jitar/saved/3l8F. Oh yea, answer the questions above so you can possibly save money!
Cpu:3570K @ 4.2GHZ|Motherboard:AsRock Extreme 4|RAM Kingston:HyperX Genesis 8GB| GPU:MSI Lightning 680 2GB |Case:Thermaltake Element V (Nvidia Edition) |Storage:Muskin Enhanced Chronos 120GB,Seagate 2TB|PSU:Rosewill 1000W modular (RBR1000) |CPU Cooler:Noctua NH-U12P SE2
MOD move this post
Guest
