I was just working on my pc when all of sudden it shutdown and now won't power up. I can see couple of lights on motherboard and gpu except that nothing. Even the case led won't turn on. Any suggestion would be of great help.
FYI everything was working fine when it shutdown all of a sudden.
Thx.
https://linustechtips.com/topic/975529-pc-wont-power-up/
Switch off power supply, unplug, check cables or possible damage (water, etc), plug back in, try again
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/975529-pc-wont-power-up/#findComment-11785991
Just now, Nick@9494 said:
Did that already even tried a different cable but still nothing.
Something has likely broken. First things first, carefully take off the water cooler and see if it leaked
Primary PC:
PSU tier list
https://linustechtips.com/topic/975529-pc-wont-power-up/#findComment-11786002
