Hey I need help with a Problem... I want to thread the conversion from a byte array to a texture. As I am informed I cant do that directly but speed up the process by converting from byte[] to color[] The Question I have is: how do I convert the two Arrays?
Thanks in advance
https://linustechtips.com/topic/975483-converting-byte-to-color/
Byte is a Single number.
Color is a structure of RGBA.
Youd need 4~ bytes for every color.
What I’d do is some kind of for loop with division to say “first 4 numbers are for color 1. Second 4 are for color two” and so on.
EDIT
Here is the Unity Documentation on Color:
https://docs.unity3d.com/ScriptReference/Color.html
EDIT EDIT
Microsoft's documentation on the Byte variable type:
https://docs.microsoft.com/en-us/dotnet/csharp/language-reference/keywords/byte
Microsoft created C#. A Byte in C#
Quote
It is the smallest number variable you can use. Values range from 0-255 or
Quote
.NET Framework also includes a signed 8-bit integer value type, SByte, which represents values that range from -128 to 127.
https://docs.microsoft.com/en-us/dotnet/api/system.byte?view=netframework-4.7.2
I hope that helps.
