if it was made longer than a year ago, yes. but they should have it included by now. don't bother with a 240mm aio for a low-end rig, use it for a better cpu/gpu instead.
https://linustechtips.com/topic/975394-pc-part-buidler-help/#findComment-11784882
CPU: AMD - Ryzen 3 2200G 3.5GHz Quad-Core Processor  ($129.99 @ Amazon Canada)
Motherboard: MSI - B450M PRO-VDH Micro ATX AM4 Motherboard  ($99.99 @ Memory Express)
Memory: Crucial - Ballistix Sport 8GB (1 x 8GB) DDR4-2400 Memory  ($74.84 @ Amazon Canada)
Storage: Team - L5 LITE 3D 240GB 2.5" Solid State Drive  ($49.99 @ Amazon Canada)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($49.99 @ Amazon Canada)
Video Card: Asus - GeForce GTX 1050 Ti 4GB Phoenix Video Card  ($209.99 @ Memory Express)
Case: Cougar - MG110-W MicroATX Mini Tower Case  ($44.99 @ Newegg Canada)
Power Supply: Corsair - CX (2017) 450W 80+ Bronze Certified ATX Power Supply  ($49.99 @ Corsair)
Total: $709.77
Generated by PCPartPicker 2018-09-24 01:02 EDT-0400
https://linustechtips.com/topic/975394-pc-part-buidler-help/#findComment-11784888
2 hours ago, NotRedRocket said:
https://ca.pcpartpicker.com/list/DyWsvn
Its saying my motherboard and Cooler may need a separate mount. Is this true?
Build something like this for now ND add in a rx580 later on....
Motherboard: ASRock - B450M PRO4 Micro ATX AM4 Motherboard  ($84.50 @ Vuugo)
Memory: Team - Vulcan 8GB (2 x 4GB) DDR4-3000 Memory  ($100.99 @ Newegg Canada)
Storage: ADATA - Ultimate SU650 240GB 2.5" Solid State Drive  ($50.49 @ Amazon Canada)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($49.95 @ Vuugo)
Case: Cooler Master - MasterBox Q300L MicroATX Mini Tower Case  ($57.75 @ Vuugo)
Power Supply: EVGA - SuperNOVA G3 550W 80+ Gold Certified Fully-Modular ATX Power Supply  ($89.99 @ Amazon Canada)
Total: $563.66
Generated by PCPartPicker 2018-09-24 03:27 EDT-0400
https://linustechtips.com/topic/975394-pc-part-buidler-help/#findComment-11785103
Yeah, I already have the asus dual 1060 3gb. I choose the 2200g because its cheap and I could OC it to 3.9. Should I get a better CPU and cooler?
https://linustechtips.com/topic/975394-pc-part-buidler-help/#findComment-11786417
no need for a cooler, stock is good enough for a mild oc. use the cooler money for a better cpu or gpu.
https://linustechtips.com/topic/975394-pc-part-buidler-help/#findComment-11787647
