help Help with H100i Pro
Solved by GDRRiley,
Just now, Rhastur said:Thanks for the reply! I had a look at that header and it appears to be a four pin header as well, I need a three pin header to connect it to unfortunately
nope you can connect a 3 pin connector to a 4 pin header. it should only fit on 1 way.
voltigeurramon ·
Posted in Troubleshooting1 -
1
Vibora ·
Posted in New Builds and Planning4 -
5
3
Doctah ·
Posted in Peripherals3 -
8
michaelb198 ·
Posted in Peripherals2
